posted by ripp73 on May 04, 2008
I have taken the cover off and the tubes are all connected and I also checked the tank and the operates fine. I was wondering if i could have a bad gravity solution valve or something else.
Thanks Steve
Solution #1
posted on May 05, 2008
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=569188
Clean water runs right out of by the brushes.
Posted by ripp73 on May 04, 2008
I have taken the cover off and the tubes are all connected and I also checked the tank and it operates fine. I was wondering if i could have a bad gravity solution valve or something else. Thanks Steve
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You may have a bad water pump, bad gasket, the water release valve could be broken, or the water tank is not sitting on the opening properly or the trigger assm is not closing properly. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hoover SteamVac Carpet/Upholstery
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
hoover steamvac
hoover steamvac
i cant get the upholstery hose... Answer This...
restrictive valve
restrictive valve
moments after starting the vac... Answer This...
when i fill the water
when i fill the water and soap... Answer This...
My carpet cleaner will not
My carpet cleaner will not pick... Answer This...
cant get upholstery part on
I know where part goes but... Answer This...
Repair Service
Find Vacuum Repairman Near You:
