Question about Yamaha RX-V563 Receiver
I have a Yanaha RX-V563 and the volume for Zone 2 is fixed and cannot be adgusted. How do I remove the volume from the fixed mode?
  • 151 Answers
SOURCE: yamaha rx-v657 zone 2 volume
Go into zone 2 in menu select the source you want then turn up the volume for zone 2,this should work.
hope this helps.
CABLE CUY.
Posted on Jun 30, 2008
  • 4 Answers
SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Posted on Aug 04, 2008
  • 4 Answers
SOURCE: volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
SOURCE: zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Posted on May 24, 2009
  • 8 Answers
SOURCE: No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Posted on Sep 07, 2009
My Yamaha RX-V563 cuts off after a few minutes with no cables attached. I feel like throwing it in the river.
You could - or you could try getting it fixed. Its good you disconnected all cables as a test. That eliminated all external causes. At this point, either the amp module or the protection circuit is bad; either probably require professional attention. Sorry - good drowning.
Nov 15, 2010 | Yamaha RX-V563 Receiver
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
Yamaha reciever model rx-v563 power cord
It's just a power cable. Get something like this
http://www.radioshack.com/product/index.jsp?productId=3875430
and lop off the end that doesn't fit, strip them and either splice it to the remnants or go inside and connect it to where the original goes.
May 05, 2010 | Yamaha RX-V563 Receiver
Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Mar 13, 2010 | Yamaha RX-V663 Receiver
Yamaha rx-v563 just stoped working no power no displayed nothing have removed plug and tried other power points still nothing help
Check the internal fuse inside the unit. If it goes again, after replacement, get back in touch with us. If OK check the transformer and the power switch.
Mar 01, 2010 | Yamaha RX-V563 Receiver
Zone 2
If you are using an external amp, "fixed" is what you will see on the Yamaha's display when you want to change the volume. If you are using the power of the Yamaha's Zone 2 outputs, you need to go into the "Menu" then "Manual Settings" then "Options or Zone 2" and set it for "Int" That will solve your problem.
Jun 23, 2009 | Yamaha RX-V663 Receiver
Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Jun 10, 2009 | Yamaha RX-V661 Receiver
Rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Jan 12, 2009 | Yamaha RX-V563 Receiver
Yamaha RX-V563 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
