Question about Cameras
My Linx Digital Photo Frame, Model Memoire 10.2B has started to have constant flickering lines across the screen when in clock mode and photo mode. I suspect an electrical surge has damaged it. Can it be repaired and if so ,where ? Mr A Baxter.
Vidéos en accéleré impossible de la mette au ralenti ou normal
Posted on Jan 17, 2011
Problems linx digital photo frame
my account has been - can I renew
Feb 17, 2014 | Computers & Internet
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have a SunPak SDPF-o8o-OSL frame. When I turned it on today instead of the photos I was expecting, I got a screen filled about 75% with colored vertical lines.0 (It looked sort of llike...
You may have mistakenly started in test mode, I suggest resetting the device, here is a link to the manual, it should have something about resetting the frame.
http://www.retrevo.com/support/Sunpak-SDPF-080-Digital-Photo-Frames-manual/id/23157bh642/t/2/
Feb 28, 2011 | ToCAD America Sunpak Digital photo frame ...
Can I download pictures direct from my computer using a standard USB lead connected directly to my Linx PHOTO8W0047932 PHOTO FRAME
* Yes, you can download the pictures from the PC to a Digital Photo Frame using a USB cable.
* Check the bundle of accessories you got with this photo frame for USB Cable.
please rate me if it helps....tc! :)
Jan 08, 2010 | Computers & Internet
Lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Dec 23, 2009 | Canon PowerShot A85 Digital Camera
How to remove a memory card from digital photo frame
Most Linx frames just require you to pull out the card. Grab it with your fingernails and pull. Make sure the unit is OFF before you do that.
May 22, 2009 | Pinnacle Linx USB Plus Video Capture
Linx Digital photo frame can't get the frame to play pictures continuously.
Change the settings from the options !!
or edit the image be4 sending to frame !!
Mar 09, 2008 | Cameras
Photo quality
send it back- it should not be like this Get onto Panasonic web site technical support team Should be in the Manual
May 26, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Cameras Logo
365 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
