Question about Kenmore Elite HE5t Washer
F71. unplugged & plugged it back. now no lights, no F71 code, nothing works
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F71 is User Interface Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit. To resolve this issue you’ll have to:
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Regards.
Ginko.
Jun 06, 2010 | Kenmore 47081 Front Load Washer
No communication between UI and CCU
Hi.
I think that by this time you already fixed the problem. The codes indicate usually a fault that is either CCU or MCU.
Regards.
Ginko.
May 03, 2010 | Kenmore Elite 45986 Front Load Washer
F71 error - no other keys work - Duet Steam Washer
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Kenmore Oasis HE 27082 Top Load Washer
What is the F71 code? How do I fix the F71 code problem?
F71 is a user interface heartbeat failure. It may not be fatal. Sometimes it is just loose wiring. Unplug the washer. In the back of the control panel, there are three screws. Remove them and gain access to the control panel wiring, See all of the wiring connections and plugs? Make sure that each connection is tight. You can press and wiggle them a bit, or you can remove and replace them, whichever is easier at each plug. Look for corrosion at the terminals as you inspect the connections. Replace the cover, plug it back in and give it a try.
Hope this gets you back up and running.
Best Regards, --WoobieDog--
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool duet ht
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE5t Washer Logo
355 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
