Question about GALAXY Microsystems 55622
My ice maker did not make ice, and now the water won't come out either!
Last Tuesday, the water department worked on the line down the street from our house. The water pressure was almost nonexistent, but I don't know whether or not the water was actually cut off. My water dispenser was spurting the water for a few hours when I filled up my water bottles, but that soon was okay. The ice maker, however, has not produced ice since then. A friend told me that there was probably air in the line, so I moved the fridge out, got behind there, used pliers, and unhooked the tube so that the air was released. I put the tube back on and tightened up the nut.
Now, I neither have ice NOR water!!
What do I do now????????? PLEASE HELP!!!!!
    Sergeant:
    Champion:
  • 347 Answers
Did u already check that the temperature is set under 17  degrees?
If it is, i was searching another post, and here
http://www.acmehowto.com/howto/appliance/refrigerator/check/inletvalve.php
you can find a picture of the intel valve, you should check if its not turning off, and if it is running continously without any problem.
Posted on May 04, 2008
Have a GE side c side and can't get water thru the
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSS25KGMAWW/0432/0165000/G0311087/00009?blt=06&prst=0&shdMod=GSS25KGMAWW
go here and look at part number 810,this is the water tank in the fridge section,get a hair dryer and heat up the tank where the water lines connect to it,also g.e. has problems with the water line in the freezer door the line freezes up.also when was the last time you changed the water filter?try this,open the freezer door and remove the bottom kickplate,on the left side you'll find a connector for the water line,disconnect it shut the door and hit the water dispenser,if water comes out of line where you disconnected it then you know the line in the door is frozen,if no water comes out i would change the filter and it that doesn't work i'd have to say you have a bad water valve.one more thing and this might sound crazy but if i didn't see it myself i wouldn't believe it,when you went to dispense water have you ever noticed that the condenser fan motor would sound like it was slowing down and also the strip in the middle where the doors close together touch it to see if it's hot,i've found three mother boards bad from this,i'd dispense water, and the fans would slow down, i hope i'm not confusing you by telling you this,lets stick with the basic things first disconnect the water line under the freezer door and behind the kickplate,shut the door and hit the dispenser,if water comes out of the hose the water line is frooze in the door,if no water comes out,heat up the water tank with a hair dryer,after a while like 5 to 10 minutes hit the dispenser but water will leak out the tube if the tanks frozen,if that doesn't do the trick i would change the water filter and if that doesn't work bad water valve,if you look down where the kickplate is you should find a tech sheet that will tell you how to jump out the ice maker,now what did you change out the ice maker?you said you changed two parts,what's happening that you changed the ice maker,was it not getting water to it,i mean if you're not getting water through the door and no water to ice maker,you either have a bad water valve or filter,start there and heat up the water tank,if that's frozen you won't get any wateralso look at this it will tell you how to start the harvest cycle on the ice maker,i beleive you shut it off for 20 seconds,turn it back on and move the arm in and out like three times.
http://appliantology.org/topic/29479-ge-icemaker-wont-fill-or-harvest/
hope this helps and good luck,let me know please what you find.
Jul 16, 2013 | Refrigerators
Mzb-12a icemaker every thing appears to be functioning but unit is not making ice
Thanks so much for the help, I was fixing to throw the ice maker down the street when I read your post I got it working. Thanks Joey Jacksonville Fl
Apr 07, 2013 | Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Water won't dispense but ice maker works
Most likely the valve has failed. Usually located in the back of the refrigerator, near the bottom - otherwise, follow your water line (feed from the house water supply).
Aug 02, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker not working on a samsung rf265aabp. water to selenoid no power to selenoid.
You won't have power to the solenoid till the ice maker dumps ice and sends signal requesting water. It only last for about 7 seconds.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | Refrigerators
Ice maker not filling with water or making ice- GE pfss6pkwss
Sep 01, 2009 | Refrigerators
Ice maker works but no water comes out from the ice maker coil
The solenoid valve that supplies water to the ice maker is leaking,so the water get frozen and when the ice maker call for water it doesnt get through,you need to replace that solenid valve.
Apr 07, 2009 | Whirlpool ED5VHGXM Side by Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
is there a filter on the water line? if so check and replace as neccesary-usually all water going into a fridge ice maker is filtered if it was installed properly for fresh tasting ice......if not there usually is a valve where the water line connects to one of your houses water line ....be careful with that but make sure it is all the way open......maybe try cleaning or replacing the lines if it comes down to it. let me know what happens.
Sep 30, 2008 | Maytag MBF2256H Bottom Freezer...
GALAXY Microsystems 55622 Logo
150 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
