Question about Microsoft Office Professional 2007 Full Version for PC
I'd like to avail of the word count tool but i don't know how.
  • Microsoft Master
  • 4,737 Answers
I am not very sure about what program you would like to avail the word count, but if you mean microsoft word (office 2007), follow the instructions below:
Open the Microsoft Word, > (1.) Right-click on the status bar, >(2.) Select "Word Count", now you'll be able to see the number of words on the (3.) status bars as shown below (labelled 1, 2 and 3)
If you need further help, please let me know with more details.
Good luck.
Thanks for using FixYa.
Posted on Aug 22, 2010
How do I manually retrieve a trouble code without scan tool for a 1997 Plymouth Voyager
Try this Turn the key on ( don not try to start), turn the key off, turn the key on, turn the key off, turn the key on and leave it on. If the check engine light starts to flash start counting the number of flashes. Those will be the codes. For about $50 you can by a code reader which will give you OBDII codes which may make it easier to figure out the problem. Post the codes and we'll see what we can figure out. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 26, 2012 | Cars & Trucks
Tie rod replacement on 1994 toyota camry
That is an easy job, especially if you have this tool, which is widely available under different brands
http://www.comparestoreprices.co.uk/images/sy/sykes-pickavant-ball-joint-separator.jpg
There is another type of tool which looks like a big tuning fork. I don't like them, as they tend to cause damage to the parts.
http://www.northerntool.com/images/product/images/9094003_lg.jpg
Mark the tie rod end and its locknut, and the steering rod, before removal, and count the number of turns needed to remove the old tie rod end so that you can install the new one pretty nearly in the same position. You will still need a wheel alignment after. More info is here.
http://www.turboninjas.com/camry/sr.pdf
http://www.turboninjas.com/camry/sa.pdf
Jan 30, 2012 | 1994 Toyota Camry
No what should i do know, don't have tool scanner
Try turning ignition switch thre times, without start engine ( ON / Off / ON / Off / ON ) and count the blinks light two short means a 2, space and one short flash measn 1, so code 21.
Keep us updated.
Oct 15, 2011 | 1994 Plymouth Voyager
FOXCONN MOTHERBOARD UYD761904374 PC661M04 MX 6L Will NVIDIA GeForce 9300 GE graphic card work with Foxconn motherboard UYD761904374 PC661M04 MX 6L. Please help me. I want to install windows 7 and use...
System Ram doesn't count for Gpu ram so 2 gig Ram and 2 gig Gpu will be fine .. check also Psu some Gpu are hungry for power Mine is Gtx770 8 pin + 8pin at 240watts.. hence 750 watt Flower power Psu...
Jul 01, 2017 | ASUS Computers & Internet
I need to change the rear gear sprocket, but don't know what speed the mountain bike is. How can I tell what speed the bike is.
Count the cogs, duh. You're going to need some help even after you know if it's 6-, 7-, 8, 9- or 10-speed in the rear. Special tools and 'how-to' knowledge. Take it to a Bicycle Shop an experienced DIY cycling friend.
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Sep 01, 2011 | Cycling
My Husqvarna 128ld trimmer will run but only at low rpm. I cant find a tool to adjust the carb. If I choke it 1/2 it will run at higher rpm, I suspect a fuel problem. It started in an instant.
If it is a newer trimmer it has a little plastic deal on the adjustment screws to prevent adjusttment.(epa). You have to break that off then a screw driver will work. Some are tough, turn hi speed screw counter clockwise it will rev
Sep 26, 2010 | Husqvarna 28cc Gas Line Trimmer
I am trying to remove 2 links from a ladies indiglo watchband
mcdevito75 here, To remove the links from any watch band requires a special tool called a Link Remover tool, available on ebay. You can remove the links without the tool but the time and work, just isn"t worthit, even with the tool if you don"t know anything about watches, your best bet would be to look for a small watch repair shop in your area , and have them remove the links, hold onto these links in case you need to ever replace them.
Aug 26, 2010 | Timex 2J611 Watch
How do you remove a drivers side door panel
You require a specialty tool for doing this. Chances are you will also need to replace the clips that break during the procedure. First though, you must remove the arm rest. Look for any roundish plastic plugs that are consealing the bolts. Remove the arm rest first, pop the clips with the clip tool available for any auto parts supply place. Disconnect cables at connectors as they restrict you as you go. There is no need to cut anything and lable the arm rest bolts because they will be of differing lengths. Count on breaking a few plastic clips though. Good luck and please let me know.
thx
ash
Jan 24, 2010 | 2005 Pontiac Bonneville
Using aol computer check up .. i get reply that hard disk is almost full.. one click fix provided does not resolve problem .. what alternatives are available ? thank you hkensky@aol.com
From my-computer right click on on hard-disk / properties this will show you how much free space available. Windows has system tools to check your hard disk for problems, like scan disk, disk cleanup, and disk defragmenter. Click start/hellp and support for more info. If you don;t find what you need let me know. Larry
Mar 08, 2009 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
