How to erase my entire mp3 - Audio Players & Recorders
    Problem Solver:
  • 32 Answers
Format device under "my computer" or go through the tedious project of deleting one at a time.
Posted on May 04, 2008
All of my file got erased on my coby mp3 610 when i preased the reset button
When you reset a device, it often clears the entire memory of the device and reverts to original settings. you can copy all of the music back on from a computer, but won't be able to retrieve it on the device.
May 04, 2011 | Coby MP-610 MP3 Player
Problem with memory/erasing discrepancy
I did erase all from the device main menue after having copied them to my computer, that cleared the remaining files and recovered part of the memory. Then I did reformat from the same menu and recovered the entire memory! ;)
Oct 20, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Erasing music from my sandisk sansa express mp3 player
you might have to erase each song by hand.. i had to erase all my songs and in my player make sure i only have the song once
Sep 03, 2008 | SanDisk Sansa e250 MP3 Player
Sansa doesn't show any songs
Use Windows Media Player to delete songs. Click on the song name once and then press delete on your keyboard. Reformatting will erase all the songs, but don't reformat unless you are experiencing some issue or another.
May 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa is unable to synch new music and only has 5 "bad tracks" on it that I can't delete...
Two possible methods:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 29, 2008 | SanDisk Sansa e250 MP3 Player
RCA PEARL MP3
after formating mp3 player. entire data is erased. copy new songs to mp3 player.
Dec 19, 2007 | Philips GoGear SA178 MP3 Player
ILO MP3 Player
OK well you may be able to recover these file by using an Un-erase program.. Usually when "Windows" deletes something it doesn't actually "Delete" the entire file, no... usually it simply removes the first letter of the file name and replaces it with a non-displaying character.. Say File.MP3 would then be ?ile.MP3. So try one of the proggies here---> http://www.dirfile.com/freeware/unerase.htm Good Luck.
Jul 25, 2007 | iLO (2 GB) MP3 Player
MP3 music format
u gotta put ure Mp3 player in MSC mode. Thats the usb mode that lets u do anything like if it was a noirmal hard drive. To do so 1.Go in ure mp3 menu 2.select the settings tab 3.go to Usb tab 4.and select the MSC tab 5.now plug your mp3 player, and you should see your mp3 with a letter under Mycomputer
Jun 28, 2007 | SanDisk Sansa m240 MP3 Player
Sansa m230 Help Please!!!!!!!!!!!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Feb 22, 2007 | SanDisk Sansa m230 MP3 Player
49 people viewed this question
 Grubhead
Grubhead
