Your hdlp lamp is burning out. You need a new lamp. Look online for lamp by your model number. In instruction manual of tv it shows you how to change. Takes 20 minutes to change
You have the classic "blue blobs," In most of Sony's rear projection LCD's, the Optical block is bad. Manufacturer's defect. The blue panel inside of the optical block starts de-laminating (due to heat from the lamp). This is a very common problem. I have changed about 70-80 optical blocks myself over the course of about 4 years.
There is no other fix but to replace the optical block. Unfortunately, it will get worse, and will probably develop "stars," or stuck pixels, as well. You can call Sony and try to get some assistance, but the extended warranty on these sets has recently expired.
I had the same problem w/ the same TV about 6 months ago. You need a new optical engine. Hopefully you are still under warranty. Once that was replaced, the tv looks great.
