Question about Blackburn Mountain Air Mountain Bike Pump 4 Bicycle
How do I pump a presta valve with the Blackburn Mountain Air Bike Pump 4 Bicycle
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
They should be designed to fit both styles of valve, but you need to reverse the seal.
you should be able to unscrew the end, remove the sealing rubber and a plastic fitting that pushes on the valve, replace them the opposite way around ,and they will fit the presta.
Posted on Aug 22, 2010
2 Suggested Answers
How to attach bontrager pump to presta valve
This pump does not need any presta valve adapter, the head unit is a dual unit for both presta and schreader.
1. On the bicycle tube. Open the valve by unthreading the small metal cylinder located at the very end of the valve stem. DO NOT force the the bead to come off of its threading. A couple spins counter clockwise will do the trick.
2. Insert the valve stem into the filler head. The lever on the back of the filler head should be "down" at this time.
3. Connect the filler head to the valve stem by lifting the lever on the head "up".
4. The valve stem and the handle on the filler head are now in parallel to each other, basically inline with each other.
5. START PUMPING.
6. If loosing considerable air while pumping, Try reinserting the valve in to the filler head, deeper, for a more secure fit.
If the issue persists, use a presta valve adapter on the valve stem. Traditionally used to convert presta valve heads to schreader heads, for use with filler heads not compatable with presta. A one dollar part available at any bike shop. Usually used in a pinch while airing up at gas stations or with schreader only pumps.
Dec 27, 2012 | Bontrager Supercharger Floor Pump - cycle...
I am buying a bike pump. My Tires Kenda Comfort w/ puncture resistant K-shield 26x1.95 on The Classic Serene 2010. Do they have standard valves or presta valves. Can you recommend a floor pump for me.
Tires don't have valves. TUBES do. Can't you tell by LOOKING at them?
http://en.wikipedia.org/wiki/Schrader_valve#Presta_valves_vs._Schrader_valves
Either way, you should buy a pump that serves both types. Stick with name brand - Blackburn, Park Tool, Topeak. Get on the web and read some reviews.
Jul 08, 2011 | Diamondback Serene Classic Women's Sport...
I can't seem to use this on my bicycle tires. what am I doing wrong?
What kind of valve do you have on your bicycle tires - standard (like a car) or Presta (narrow with manual screw down valve)? If you unscrew the head of the pump you should be able to reverse the rubber gasket to fit each type - wide for standard and narrow for Presta.
Jun 03, 2011 | Schwinn Bicycle Aluminum Frame Pump
The pressure gauge on my Topeak Joe Blow Ace floor pump is not working. The pump works fine. How do i take the pump apart and what should I be trying to do to repair?
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Jan 09, 2011 | Topeak Joe Blow Ace Floor Pump
HOW DO I PUT AIR IN A MOUNTAIN BIKE TIRE WITH A PRESTA VALVE WITH A TOPEAK MINI MASTERBLASTER PUMP.
Nov 02, 2010 | Topeak Mini Master Blaster
I have just purchased a Topeak Mountain Morph pump, which can be used with both Presta/Scrader valves. I have a presta valve on my bike, but am not able to inflate my bike. Not sure if I am doing...
Aug 25, 2010 | Topeak Morph Pump
How do I use a Blackburn Mountain air pump?
Dear Doug, to lock a hand pump onto the valve stem: 1.depending on valve type-loosen the valve lock for presta, twist off valve cap for schrader. 2.unlock the pumping handle from the pump so that you can actually "pump" the pump... 3. put the pump head on the valve of the tire, then pull up on the thumb tightening lever. This should squeeze toghether the internal rubber gasket of the pump, and lock on to your valve. 4. Begin pumping. 5. when desired pressure has been reached, push down on the thumb lever to unlock the pump. Remove it. Good Luck Fellow bicyclist!
Jan 18, 2009 | Blackburn Mountain Air Mountain Bike Pump...
Blackburn Mountain Air Mountain Bike Pump 4 Bicycle Logo
788 people viewed this question
Top Blackburn Cycling Experts
Donald Ayers-Marsh
Paris Johnson
Paris Johnson
Level 1 Expert
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
