Question about Krups 203-42 Electric Blades Grinder
Where can I buy a lid for the krups f203 coffee grinder?
  • Anonymous Mar 28, 2014
    how to disassemble
    open motor base
  • 490 Answers
Here is the url for Krups online parts. Happy caffeination:)
http://www.krupsonlinestore.com/product_list.asp?MENU=parts&SELECT=grinders&SKW=acccoffgrind
Posted on Aug 22, 2010
How do you change the blade? I bought a new one but can't get the old one off. Thanks
Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.
    • 1 Unplug your Krups grinder from the wall.
    • 2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
    • 3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
    • 4 Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.
    • 5 Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut.
Things You'll Need
  • Cloth
  • Safety gloves
  • Channel locks
  • Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Krups 203 Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
Hi, i have the krups 203 coffee grinder mill. i have misplaced the lid. where can i buy a new one? thanks
Here is the link
Jan 13, 2011 | Krups 203-42 Electric Blades Grinder
I just got a brand-new Krups F203 grinder. I was grinding up a whole bunch of coffee at once and at about the fourth cup of grounds, while the button was still pressed down, it just shut off. And now it...
You may really have overheated it and it may not have a self resetting thermal fuse. Probably best you say nothing and take it back for repair or replacement under guarantee. When you are up and running again do much less grinding at one time.
Aug 06, 2017 | Krups F203 Grinder
The grinder runs intermittently. Sometimes it help to jiggle the lid and the switches on the front & side.
There is LIKELY a safety interlock switch for the lid to prevent operation if the lid is not down tight. Suspect the problem is with the switch or an latch that holds the lid.
Jan 12, 2010 | Krups GVX2-12 Electric Burr Grinder
Cannot get my krups burr grinder gvx 2 to turn on or do anything. there are no instructions in the box.
The GVX2 has two micro switches. one on the top hopper (in the groove on right hand side) and the other in the space the coffee holder (collector) fits into.
The coffee collector micro switch is activated by the lid of the collector.
You have to listen for a small "click" as you place the hopper on and again as you insert the coffee collector.
regards
Philip Williams
Sep 28, 2008 | Krups GVX2-12 Electric Burr Grinder
Fill out water
The Krups Burr Grinder GVX2 featured in the picture is not a coffee maker, per se, it only grind coffee beans to use in other coffee makers. It is a lousy machine, and I would recommend returning it or not buying it.
DO NOT PUT WATER INTO THIS MACHINE. It will cause electric shock.
Aug 24, 2008 | Krups GVX2-12 Electric Burr Grinder
I bought a Krups GVX2 coffee grinder and am not able to get it to work. I have followed the instructions "to the letter" but once it's plugged in and switched on, the "on" switch on...
I know that this machine is sensitive with the lids needing to be securely fastened (both the top and the plastic catch bottom container) maybe that is it.
Jul 14, 2008 | Krups GVX2-12 Electric Burr Grinder
Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
Feb 19, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups 203-42 Electric Blades Grinder Logo
423 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
