Question about Acer Aspire 5610-4648 Notebook
The screen on my Acer 5630-6288 flickers constantly. The only option for refresh is at 60 (although some have said problem disappears at 75).
    Scholar:
  • 122 Answers
You could try updating the video drivers.
Here is a direct link for your laptop, an Acer Aspire 5630.
Download either the VGA Intel driver or the VGA Nvidia driver. Depending on what your laptop video card is.
Then after you install the updated drivers, open the video and search for the refresh rate. There should be an option to unlock further rates, (although it is not recommended) then by unlocking this, you should be able to choose 75hertz. * I would go no further than 75hertz*
Although updating the video drivers might fix the problem on its own.
Hope this helps.
Posted on Aug 22, 2010
Screen is flickering constantly and goes black after a while
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments. As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting. If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate. If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet Hope this helps.
Jan 17, 2013 | Dell Inspiron 1501 PC Notebook
Black screen Laptop. Flickers once on start. External Monitor works
Jan 15, 2013 | Computers & Internet
Laptop screen keeps flickering
Changing the refresh rate might help.
Right click on the screen. In the box that comes up select Graphic Properties. In the window that comes up click information. Box that comes up select monitor tab. Will have a list of display sizes and refresh rates that are supported by your monitor. Once you have that information you can make changes.
FYI: Acer says max resolution 1920 X 1080 with 75 HZ refresh rate.
Also if you have a tube light or speaker system close to the monitor then try moving it further away.
Apr 30, 2012 | Acer Computers & Internet
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Monitor flickering
hi tim, get the latest drivers here : http://support.acer-euro.com/drivers/downloads_gd.html
o/s is abbreviated for operating system = windows
kind regards
Jan 17, 2010 | Acer Aspire 5920-6335 Laptop
Refresh rate for this monitor. Prefs. offer 60 or
Go for the highest your video card will allow to remove any flicker from the screen, or the max whichever works best.
I also have a Viewsonic Flatscreen, they are great and I had two Viewsonic CRTs before that.
Nov 28, 2009 | ViewSonic VA702b 17" LCD Monitor
Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Oct 29, 2009 | Computers & Internet
My LCD monitor is blinking very frequent.
When the refresh rate changes then the screen will flicker. Change your refresh rate to above 75.
Here is how: Click on Start>Control Panel>Display>Settings>Advanced>Monitor>and you will see screen refresh rate. Change to higher rate.
Rate this solution.
Jan 09, 2009 | Acer Aspire 4315 Notebook
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Moniter flicker
Any monitor flickers at 60 hertz. The usual reason for being unable to use faster refresh frequencies is that the correct video card driver and/or monitor driver are not installed. Another possibility is that the resolution is set too high. Assuming Windows XP, right click on the background, choose "properties", settings tab, advanced button. Check to make sure your video card is named - the monitor is not as important but would certainly be helpful. If not, did out the CD's that came with them or download drivers from the manufacturer's website. On the other possibility, on the adapter tab, there ought to be a "list all modes" button so you can choose resolution and refresh rate at the same time. Your LCD monitor will be fussy about the resolution, so you may need several tries to get something that looks good and doesn't flicker.
Sep 12, 2007 | Acer APFV MT (APFVUP5152) PC Desktop
Acer Aspire 5610-4648 Notebook Logo
183 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
