Question about Vacuums
I have a vacuum cleaner model Z5245 and the flexible hose keeps sucking together and stopping suction. This is the bit with the stop start controls on it. How do I repair this or replace it?
  • 328 Answers
If theres a clog, then youll have to remove the entire section of hose from the vacuum and use a non blunt stick - bamboo sticks are excellent for this purpose. Stretch the whole hose out and put the stick down the hose until you can wriggle the stick down the hose - this usually gets rid of most clogs until it falls out - then you may have to reverse the hose on the other side to dislodge anything which gets stuck from the control side.
You may have to take your model back to Eureka/Electrolux for it to be repaired if theres a clog.
Posted on May 04, 2008
I have a DC41 Animal. It has suction through the hose. When I try to vacuum it stops sucking through the hose but seems to have no suction in the base and the beater roller doesn't work.
Check for a clothes peg at the motor iintake port. They can get that far then jam at the curve so tight youll wonder how you missed it. It will drastically reduce suction yet not cause a clog , and you can't see it
Feb 09, 2017 | Dyson DC41 Animal Bagless Upright Vacuum...
No suction
How to fix loss of suction in a vacuum cleaner - YouTube
? 3:50
www.youtube.com/watch?v=WDiBVdpHjUY
Mar 16, 2011 - Uploaded by eSpares For all your vacuum cleaner spare parts go to http://bit.ly/1DgUyt2 If your ... Dyson not sucking and not picking up dirt. no suctionhow to repair ...
Sep 30, 2015 | Vacuums
No suction through hose
How to fix loss of suction in a Hoover upright vacuum cleaner
? 2:37
www.youtube.com/watch?v=wXFKq67AHqE
Mar 16, 2011 - Uploaded by eSpares For all your hoover vacuum spare parts go to http://bit.ly/1wGC60b If your vacuum isn't sucking, the problem...
Aug 03, 2015 | Hoover U8185-900 Upright Vacuum
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
My 5200 hoover spin scrub all of a sudden stopped sucking in mid clean.i took the front clear cowling off and checked for blockage but couldnt see anything.there is nothing to these thiings,they are...
Most likely your vent for the suction container is plugged or the suction hose can of or is broken at the connection to the tank nozzle (very common on these. Clean the machine thoroughly, and check that all hoses are tight and connected.
Aug 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover tc5238 bagless cylinder vacuum cleaner - no suction
You have a clogged hose. Sometimes a Q-tip or something like that gets sucked up and then stuff jams up against it. You can use a long stiff wire with a hook bent in the end to reach the jam and work it loose. Just be very careful not to poke the wire through the hose! Work slowly and get the clog out a bit at a time.
The clogged hose would also account for the red light.
Apr 08, 2009 | Vacuums
Machine turns on, has little suction, then stops working.
It would be helpful to know what model of vacuum cleaner you're talking about. Basically though, your machine has a blockage somewhere (hence very low suction), and is cutting out after just a few minutes because of overheating.  You need to explore the suction hose (or whatever your machine has), find the blockage and remove it. Blockages almost always happen where the pipe-work takes a sharp bend.  In the worst-case scenario (although in almost all modern machines this is not possible) the blockage may be in the vacuum fan enclosure itself, and then you'll probably need a professional to take care of it.
Feb 03, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Hose attatchment won't suck
Sounds like you have a clog, either in the hose or the inlet down by the brush roll to where the hose plugs into.
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
