Question about Timex 27191 Wristwatch
I put the battery in it works i snp the back on it quits
  • 490 Answers
Cut a tiny piece of saran wrap and lay over battery area before replacing back. This sometimes solves a shorting issue. Hope this helps:)
Posted on Aug 22, 2010
My Coifman sc0170 has stopped working , I've only worn it 6 or 7 times i bought it in March 2016 , after wearing the watch I always put it back in its box any I dears plz
I see that this is a quartz chrono. Firstly, make sure that the crown (winder) is fully pushed in. If you have had the chronograph function running all the time, this will deplete the battery quite quickly. Also, when you buy a watch, depending on where you bought it, it may have been running for some time perhaps as a display model so the battery might already be well used.
If pressing the crown in doesn't sort it, get the battery replaced. If that doesn't get the watch running then you should return it as faulty (as it was a very recent purchase). If battery replacement does get the watch going then you might want to read the manual to ensure that you're not constantly running the chrono function, which will seriously reduce the battery life..
Jun 05, 2016 | Watches
How to replace second battery in lorus z011 watch
I just replaced this battery myself, it wasn't easy, but is doable. First, you will need some tweezers, a tiny phillips, and a tiny flat blade screwdriver. Totally at your own risk!
- Remove the 4 small screws on the back of the watch
- You will see a large battery under a metal clamp, this is for the back light. Remove the two phillips screws securing the clamp, and put that aside with the battery and screws. The clamp also has a metal flap on the side that acts as part of the mechanism for the back light button.
- You will now see the second battery hiding under the circuit board, it will have a small black circular rubber sticker on it. Remove the third remaining screw (very near the right hand one you have already removed) to take off the circuit board. It is clicked down slightly onto two lugs, so prise carefully at the left and right to free it
- At this point be very careful not to tip the watch upside down. There are two very small brass springs which make contact with the very top and bottom underneath of the circuit board, which now they are removed could easy fall out
- Under the circuit board is a plastic sheet, remove carefully with tweezers
- You are nearly there! There are three flat head screws, I got away with just undoing the two nearest the battery, and the third I loosened off enough to carefully lift the metal up to get the battery out
- Carefully remove black sticker, and put it on the replacement battery instead, and now reverse the entire process. Getting the metal clamp back on to secure the battery, and put the screws back is really quite fiddly, make sure it is help down properly
- Make sure before you put the circuit board back, that the two brass springs are in place. When putting the metal clamp over the larger battery, make sure the metal flap that is pushed by the backlight button is in place properly.
Avoid touching anything inside the watch with fingers, use tweezers to remove screws and parts, and make sure you keep track of which screws went where. Good luck!
Jan 26, 2012 | Lorus Watches
How do I set the month on a seiko coutura snp-008 ? I have moved from a previous address and cannot find the manual for the above watch. where can I get the Manual?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SEIKO watch manuals.Rate me, please.
Mar 30, 2010 | Seiko Coutura Chronograph Watch
The watch just quit working. I had the battery replaced and it still does not work. Anything else i can do? Chase Durer Blackhawk mach 3 Black/silver watch.
go back to whoever replaced battery first ask them to check battery not faulty then if battery ok ask them did they AC the watch when fitting battery any repairer who knows what they are doing will know what you mean, if they dont find a decent repairer..other option have it serviced..
Mar 25, 2010 | Chase-Durer Blackhawk Mach 3 Alarm...
Starts and stops
take and have it cleaned and oiled
Aug 05, 2009 | Columbia Elkhorn Countour Watch
Light won't work
I suggest you have to check your battery first. It may be underpowered. Replace it with the new one and then check light again.
Dec 19, 2008 | Polar F6 Wrist Watch
Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Apr 26, 2008 | Casio Atomic-Solar Watch GW300
Changing a watch battery
I used a sharp penknife blade to remove the watch front by getting right on the base and pinching the glass off, (comes off quite easily) tilt the watch out of the case and see enough to prise battery out with a needle. The battery is a Maxwell SR920W or equivalent. Have ordered new batteries on ebay.
Oct 04, 2007 | Watches
Timex 27191 Wristwatch Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
