Question about Sony Cyber-shot DSC-T90 Digital Camera
I have a sony dsc-t90 camera when i turn on the power there is error massage {for compatible battery use only}i change a new battery but the problem is still there so is there any body can help me what is wrong with this camera?is there any way to fix the error.
  • 27 Answers
The compatible batteries for this Camera are NP-FD1, NPBDL.
Please make sure that you're using compatible battery pack.
Remove and reinsert the battery pack, while the Camera is turned off.
Reset the Camera by removing the battery while the Camera is ON and reinsert the battery after a minute and turn on the Camera.
If the issue is not resolved the Camera needs to be serviced, as it will be the issue with the hardware part of the Camera.
Posted on Aug 22, 2010
Backlight spoilt for dsc t90
When the display is to dark or to light, the manual says:
Adjust the brightness of the backlight (page 18).
On page 18 it says:
This sets the brightness of the LCD screen. When viewing images in bright outside light if [Brightness] is set to [Normal], reset to [Bright]. However, the battery power may decrease faster under such condition.
You also can press the button with the > logo, to change between view pictures and record.
Dec 08, 2013 | Sony CyberShot DSC-T90 Digital Camera
I'm unable to shoot movie on my sony camera dsc t90. when i press on record i get the following msg:system error c32:01 pse help
Error C:32:01 indicates problem with memory stick in camera, format memory stick through format option in memory stick setting option in camera setting menu and check.
If problem still not solved then put new memory card/ stick in camera as this memory card would be defective.
Thanks.
Dec 25, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Sony camera dsc-t90 when we switch on the camera the screen become blarred nothing is visible screen is full white with some line
Hello
OK, this can either be that your LCD has an internal crack. You can actually test it by doing the following. If you power on the unit and you can still take a photo, which comes out normal, it is a bad LCD.
You can get the LCD of your camera repaired at your nearest camera repair store for under $30.
If the camera does not take a photo when you snap something, it can also be a lens error.
For now, test the above solution. Let me know if you need any further assistance.
Kind regards
Andrea
Nov 26, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Is there a docking station that is compatable with the Sony Cybershot DSC-T90? I am unable to upload photos straight from the camera as the battery dies before completion.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
I suppose you could consider a card reader as a docking station, though it doesn't connect to the camera.
Nov 09, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
How can i find dsc-t90 skd 694953 serial number
The serial number on the Sony DSC-T90 is located on a label attached to the bottom plate of the camera.
Hope that helps,
BAX
Mar 21, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Red light appears at bottom right corner when turned on
The DSC-T90 contains a focusing light that turns on when the shutter is depressed half way down. This allows the camera to focus in near darkness.
Mar 10, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Sony cybershot DSC T90 got wet in rucksack one day when we went out walking. Now it won't turn on. Is this fixable?
Please try to power reset the camera and try. To reset, please remove the battery and press n hold the power button to on position for 1 minute. Then, release the button and insert the battery. If the issue persists, please contact service center.
www.eservice.sony.com
Oct 18, 2009 | Sony Cameras
Sony Cyber-shot DSC-T90 Digital Camera Logo
281 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
