Question about GPS
When my Garmin 2720 is hooked up either to the car or in the house, it lights up comes on but cannot find a satellite.. this is on a sunny day. I've had it for 3 years same location and never had this problem. It also says in upper left corner GPS off?? Not sure what that means there is no setting to turn it off and on other than the on/off switch.
  • spedski Feb 08, 2009
    My Forerunner says GPS off when I first put it in training mode. It does not search for Sats. I have reset it several times but It still does not try to aquire a GPS Signal.
    What should I do next?
4 Suggested Answers
  • 7 Answers
SOURCE: touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Posted on Jan 24, 2009
  • 3289 Answers
SOURCE: Garmin gps keyboard -- left upper corner fails to
Sounds like you need to recalibrate the screen. This can be done by following the steps below:
To Calibrate the Touch Screen on a zūmo®:
1. Turn the unit Off and make sure it is not attached to any outside power source.
2. Power the unit On, continue to hold the Power button for 1 minute. 3. A screen will display that says, Press dot in the lower left corner. 4. Release the Power button and touch the sequence of dots until your unit says Calibration complete.
Posted on Sep 19, 2009
riceski
  • 1851 Answers
SOURCE: nuviĀ® 255W Car GPS Receiver: The screen of my Garmin nuvi 255w GPS is white and...
Press and hold the lower right corner - then see second picture
Posted on May 21, 2010
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
The hazzard light comes on everytime i open door. goes off a few minutes after i drive off. And I've noticed it goes off quicker when it's very sunny
is it the hazards or is the alarm going off look for a small button under the dash a push it with the key in the run position
Aug 12, 2012 | Cars & Trucks
Can't aquire satellites
If it is a streetpilot 2720 also may work on other models...
Turn unit off hold down menu button while turning unit on and, hold button down till a white page comes up that says general.
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work it did for me.
May 28, 2010 | Garmin StreetPilot 2720 GPS Receiver
Garmin 2720 keeps dropping the satellite connection
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work.
May 26, 2010 | Garmin StreetPilot 2720 GPS Receiver
Voice activation capabilities locked and none functioning after driving for 2 hours or so. Satellite reception getting lost even on a sunny day
I can help you reset and fix your Garmin Nuvi 265W.
Erratic behavior and improved satellite reception has been addressed in new system software / firmware update.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Sep 22, 2009 | Garmin Nuvi 265W GPS Receiver
How does one update th gps?
You connect the 2720 to your pc with the supplied usb cable.
Power up the 2720 with the ac supply cable.
Then run the garmin webupdater. It will do the update.
You must have previously installed the webupdater and the usb drivers. If you use the garmin mapsource software and can connect to the 2720, to transfer waypoints, tracks, etc., then the usb drivers are already installed.
You can download the webupdater at this site:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Hope this helps.
Feb 24, 2009 | Garmin StreetPilot 2720 GPS Receiver
Searching for satellite but never finds - what is wrong?
I had one like that last year, I found if I lied to it when it asked what state I was in, then it would find the satellites and work fine ... until the next time you turned it on. That one was fixed by installing new v7.2 firmware using Garmin WebUpdater through the USB port.
I've got one right now that won't find the satellites and the firmware trick didn't work. That's all I've got so far. Tom.
Jan 13, 2009 | Garmin StreetPilot 2720 GPS Receiver
Garmin GPS 2720
Unfortunately, Fixya is not associated with Garmin. We can only answer device questions and can't speak for the company.
Unfortunately, the unit cannot be upgraded. Garmin provides both in and out of warranty repair service if the unit is having a problem. The 2720 sells for $49 on Amazon, so it probably is not worth your while to have fixed.
The 2720 is known to have issues unfortunately, it is pretty lowly rated on Amazon.
Mar 23, 2017 | Garmin StreetPilot 2720 GPS Receiver
My Garmin has stopped finding destinations - just says "Searching for Satellite)+
I had the same problem with my Nuvi 310. Found a solution in here that works. Here's a copy of the advice.....note you will need to get in the car and set it for a destination and go. 5-10 mins later the Garmin Nuvi will lose the satellites, but don't adjust it it, leave it on and keep going. Eventually after about an hour it will right itself, pick up the satellites and evrything will be back to normal.
Here's the advice:
happy2surf
Rank: Apprentice
Rating: 81%, 49 votes
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching!
The unit appeared to have "stuck" in this acquiring mode. The following worked for me:
1) open the GPS antenna
2) press the bottom left screen while holding the power button to turn the unit on
3) enter maintenace mode
4) select diagnostics
5) clear error report, do NOT clear any user data
6) restart unit the usual way
My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Dec 05, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
70 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
