It shows one horizontal line. i replaced vertical IC TDA8350Q but i found two diodes which are burned out but i don't know the correct value which are DZ302 & DZ303 and DZ 300 is shorted while Resitstor R408 is open Diode VD 405 shorted and DZ 612 is also shorted.
tvtek
  • 1284 Answers
SOURCE: Samsung Plasma PS-42P3S
Sounds like a bad digital board to me. It processes all the video information.
Posted on Feb 09, 2007
torgo
  • 19 Answers
SOURCE: D20 Diode value on Motherboard.
Contact Dell support. Tell them that you were told by a tech (that has repaired many of these problems) that you believe you have a motherboard with leaky capacitors (do not mention the burnt out diode, just tell then it no longer boots). After much interaction with Dell technicians, it turns out that dell has extended the motherboard warranties of most of their PC's including laptops. I know of two people so fat that have had Dell warranty repairs done, even though the system was out of warranty. Once they hear "leaky capacitors" they will advise you that even though your unit is out of warranty, they will replace it. Hope that helps! Best regards
Posted on May 04, 2007
  • 556 Answers
SOURCE: LG 500G MONITOR
as your h/output got defective due to short circuit.proceed as follows. isolate h/output section fom power supply& check power supply output is ok as you know high output may give such problem. when it becomes ok, check hor.section 1 h/output 2 cap & diode connected in eht winding. 3 ptint short near eht. 4 at last eht tranf. 5 if it is ok re connect h/output supply. put on set. your que AFTER CHECKING I FOUND A DIOD(MUR460L)SHORT.I WANT TO KNOW THE FUNTION OF THE DIOD AND THE EQUIVALENT DIOD FOR REPLACE (BECAUSE MUR460L IS NOT AVAILABLE IN OUR LOCAL MARKET). 1 Function of diode is to convert AC TO DC 2 you can use BF159 or BF157 as equivalent.
Posted on Sep 26, 2007
  • 208 Answers
SOURCE: LG 42PC3RV module LGEPDP burned hybrid IC
If the buffer drive bds. were replaced along with the ysus and zsus and this problem occured it is definately and defective pdp.
Posted on Feb 15, 2008
  • 2318 Answers
SOURCE: Burned out rister-r657 and diode--d637
I could find a place to get a free download.
Check HERE but you have to pay for a download.
Or you can check this site for complete assemblies for your TV.
Posted on Mar 13, 2008
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
WHAT IS THIS PROBLEM R805 RESISTOR 33 Ohm BURNING how this solvation sharp tv?
Vertical output IC shorted. Replace it. Before replacing it, check all the associated components connected to its terminals for failure; especially for any zener diodes for short. It is most possible case. Refer its circuit digram [schematic diagram] for more details.
Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Televison & Video
NEED TO ADJUST VERTICAL PICTURE
Replace capacitors CX2105 (35 volts 220 Mf), CX2110(35 volts 100Mf), C2104 (50 volts 1 Mf), resolder resistors RX2115, RX2116,R2118,R2119. You will need to also resolder the vertical IC. I think this IC location is IC 2200, its been sometime since I repaired this one.Do not short the pins together with excess solder. The values on the cap may not be exact. Please use the cap value that is removed (remove and replace one at a time). The locations will be correct! This will remove the horizontal lines or bars across the TV screen. You may as well replace capacitors in the horizontal deflection area. By now you have bad caps there. The locations and values are, CX3218 (160 volts 2.2Mf), CX3205 (16 volts at 100 Mf) CX3413 (50 volts 22 Mf) and CX3416 (25 volts 100Mf). Thanks for asking and show all hands of support.
Jul 14, 2011 | Zenith B25A02Z TV
Hi my TDA8350Q IC keeps burning out in my[ GE 25GT538 25" TV] ....can u tell me the cause of it...?????...an how to repair it...thanks...ps email...greene-b13@hotmail.com
Hi greene_b13,
Check you vertical yoke for shorts.
Make some re-soldering around the vertical section circuitry.
Check the diode around the vertical section circuitry for shorts.
Replaced all electrolytic capacitor in that section.
Thanks for visiting Fixya.
Apr 04, 2011 | GE 25GT538 25" TV
My TV picture has collapsed to a single horizontal line
If it is an standar analog tv, I'm sorry to tell you but, is time to get a new one.
Dec 05, 2009 | Panasonic Televison & Video
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Apr 19, 2007 | Sansui TVS2750 27"
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
