Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I used liquid fabric softener for the first time, and my washer stopped. Got a message LF.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
Fabric softener dispenser
You could have something jammed in there
Aug 10, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Residue left on clothes from no agitator top load GE washer
Do you use liquid laundry detergent & liquid fabric softener? If you do then this could be the source of the residue that is getting on your clothes. Over a period of time the gummy residue from liquids will accumulate between the tubs. You can clean out the washer with a product called Washer Magic or the unit will need to be disassembled & cleaned thoroughly by hand. Do not let raw liquid detergent or fabric softener come into contact with your clothes.
Also, here is a link to the agitator cap if you should need it.
Aug 12, 2012 | GE Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
Why do my "darks" come out with white residue
Jan 13, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
Where do I put in liquid fabric softener?
behind the soap dispenser is another spot for softener
May 24, 2010 | Maytag EPIC MFW9700S Front Load Washer
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Nexxt 500 washer - fabric softener tray fills with water and doesn't drain. I have not used liquid fabric softener in this machine. It is 16mo old. What do I do to stop this?
There is suppose to be an outlet that opens up at the same time water enters ( to flush out softener). That outlet is either stuck shut or the wire fell off (I believe this is a little solenoid plunger with a wire attached). It is common for wires to come loose from the vibrations of the machine
Aug 20, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
I am so disgusted with my fisher and paykel washer!! It has ruined many of my clothing items due to fabric softener...what is the deal with this washing machine? I have had Fisher and Paykel washer and...
Are you using the fabric softener setting when using fabric softener? If not the washer is not using enough water to dialute and disperse the liquid fabric softener. a traditional machine uses about 45 gallons of water fisher&paykel uses 20 gallons. If you use liquid softener you have to use fabric softener setting and negate the water efficiency of the machine. I had F&P for a few years till I moved and there are tips but I really liked mine. Hope that helps.
Jan 11, 2009 | Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
