Question about LG Refrigerators
Model GR-T282 Two door LG refrigerator ( India) Five years old. We observe that all perishable products kept on the tray does not cool properly. Infact some vegetables are getting perished very soon.However vegetables kept inside the tray provided at the bottom works fine. The freezer also seems to be working fine. What could be the problem. It appears the machine is normal.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
Benimur
  • 6966 Answers
SOURCE: refrigerator not cooling.
Hi and welcome to FixYa,
Almost always, your described problem could be either:
  • evaporator fan/blower is faulty; or
  • air passgaeway blocked or vent is blocked or closed.
The refrigerator section gets its cold air from the freezer. If the freezer is working then the frozen air would have to be drawn to the refrigerator side by the fan. If the fan is not working or the air passage way is blocked, then no frozen air would be moving towards the refrigerator side. result would be as you described.
In some instances, it could be the thermostat of the refrigerator but this would be least likely.
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Fridge is not cold freezer works fine.
Try changing the damper settings in fresh food compartment. Your refrigerator has a control board and it is possible the board is no longer working correctly. If your board is bad I can help you locate one. If the fridge is still under warranty I would have the technician come out. He would possibly just change out the board without testing to original board. Other things that could cause problems are thermistor and defrost thermostat located inside the freezer and attached to the evaporator coil. If you continue to have problems, let me know, Thanks, Sea Breeze
Posted on Mar 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
How do you remove the back panel of the freezer to remove built up ice
Borrow all the picnic coolers you can, unload and turn off unit. You might even need a couple pounds of dry ice.
Then remove the defrost drip tray and empty it. Then its OK to defrost the unit. Trying to remove ice while operating is risky and you may end up with a replacement on your hands. Don't rush it, but sometimes a hair dryer on low can help (Just left inside the door) just make sure it is kept dry.
Feb 27, 2018 | LG Refrigerators
Lg service support
Hi Linda, check the back wall of the freezer. If it is covered in frost, it's not running it's defrost cycle and the evaporator are insulated in frost, not allowing the refrigerant to do it's job. Probably a bad defrost thermostat or defrost heater. Hope that helps.
Jul 23, 2017 | Refrigerators
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Why is there heavy ice buildup in our 2 year old LG bottom freezer refrigerator model LFX25970
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | LG LFX25960 Bottom Freezer French Door...
Refrigerators Logo
157 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
