Question about General Kitchen Ranges
Hello. My electric stove smells like its burning every time I turn it on. This happens within a few seconds of turning it on low. I dont know how to fix this. Can anybody help? (Its a generic stove, doesn't have any labeling on it for a brand)
  • Rick Ead
    Rick Ead Aug 22, 2010
    the smell could be coming from the burner plate have you tried removing the plate and cleaning it what is the smell that you are smelling is it like a metal burn type smell or is a grease or oil smell the hole top half of your oven does lift up as well as you can unplug each buner from the receptacle unplug all four lift the top panel and replug in that one burner then turn it on and inspect where the smell is coming from also if oven is ld sometimes the wires tend to get brittle and break causing them to arc but that would be more of a wire type of smell please message back with more clarity on what type of smell your smelling thank you again rickead1
3 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: my oven makes an electrical burning smell when
how old is the unit and can you hear any odd electrical arcing noise from the unit,? outside of the usual low hum of the elements heating up?
Posted on Sep 24, 2009
richroth
  • 9472 Answers
SOURCE: Maytag electric range MER5765RAW1 stove and oven
The control board has gone out on the unit. You can access it by removing the screws on the back of the console panel. You will need to replace the control board with this part.
Posted on Aug 13, 2011
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
I have a stove 61ehdo stainless Steele cooker which tonight has just stopped working I've had it approximately 7yrs . Oven rings etc won't turn on . I was in the middle of making dinner when this happened...
If you smelled a plastic burning smell you've burned some wiring somewhere. You would need to pull out the whole thing and start by looking at the back. I once had a dead mouse that had shorted across the relatively high voltage terminals common on most stoves. You should unplug the stove before doing anything like removing panels. Be very careful. Once you've found the problem you might need to call an electrician to fix it, depending on how brave you feel and where the problem is.
Feb 16, 2015 | Ovens
I have a dura flame electric fireplace and I turned it one and it smells like something is burning. I tried to vacuum it and I turned it back one and it still smells like something is burning. it is a
when things are brand new that produce heat they will smell funny for awhile but give it a couple days and it will not if you see smoke then get excited and unplug.
Jan 28, 2015 | Duraflame L Electric Stove with Remote
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Frigidaire gallery electric stove too hot
You will need to replace the burner switches for the burners that are not functioning correctly.
It also sounds like you have a problem with the OCU (oven control unit), this part is known to consumers as the clock.
Do a Google search for the model number and find a supplier for the parts. All three of these parts will easily cost over $300 all together.
Also the model number you listed in missing the last 2 letters. Locate the sticker which contains your model and serial number. This sticker will be on the oven frame when you open your bottom drawer.
Apr 05, 2013 | Frigidaire Gallery GLGF389G Kitchen Range
Smoke comes out of grill on electric cooker
This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
Nov 10, 2009 | Stoves 720EF Electric Double Oven
Oven smokes and smells like burning plastic
This happened with my oven, happened twice to the same (newer) oven actually. The smell and smoke occurred both with the oven and with the use of burners on stove top. Turned out it was the main line cord which had a split. The first repair they replaced the thermol block and all the bolts holding it into place (for a total of 9 parts) the second time (about a year later) the repairman replaced the line cord and said that it probably should have been done along with the first repair. The smell coming from the oven before the repair was a toxic burning wire or burnt plastic smell. There was also smoke if the oven was left on long enough. The repairman said that the amount of heat to "cook" the connection on the line was at a fairly dangerous level. It was recommended to me by the fire inspector (who was in my unit for annual condo inspections) that it was unsafe and to have it repaired immediately. Hope this helps. Best of luck.
Oct 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
TV will not power on. Slight electrical smell
Find out what is burning and replace it. Or call for service if that is beyond your ability.
Jan 13, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Kitchen Ranges Logo
937 people viewed this question
Top General Kitchen Ranges Experts
Dan Webster
Dan Webster
D. E. Hev
Owen Barnes
Are you a General Kitchen Range Expert? Answer questions, earn points and help others
