Question about Epson Stylus NX400 InkJet Printer
Unable to create a work folder on the current disk%2C therefore the work folder will be returned to the default location
3 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: Mac OSX 10.4.11 Error when installing the Epson NX400
If you're running the install program from the install disk CD, it may be attempting to create a work folder on the CD instead of your hard drive. I would drag a copy of the install program onto your hard drive first and then launch the copy on your hard drive.
Let me know if that solves your install woes...
best of luck on this.
K
Posted on Jul 24, 2009
SOURCE: Unable to scan from Epson TX110 but can print
"unable to create a work folder on the current disk"
possible solutions:
-highlight the application then do "command+i" permission should be set to read/write.
-run repair disk utility. check for any permission errors.
-try a different admin acoount then reinstall the software
-call Mac - honestly it's an OS issue
Posted on Aug 09, 2010
Was givin a used unit and want to reset it to factory default
To reset BIOS to factory default settings, press "F10" during the POST section and then press "F5" to reinstall factory BIOS settings, Save the new settings and reboot.
To recover to a clean install of the Operating System you will need a set of Recovery Disks. If you do not have them, and the machine will load Windows successfully then you should be able to create them from the "HP Backup & Recovery Manager" although whether this will return to factory default or simply create disks for recovery to its current state I am not sure. Alternatively I understand you can get Recovery Disks from HP, although whether still available for this model - I don't know. Hope this helps.
Feb 16, 2014 | HP Compaq dx2400 Microtower - KR601UTABA ...
Having exactly the same problem with an Epson SX515W. Did you solve it?
Sep 28, 2009 | Epson Stylus NX400 InkJet Printer
Samsung Tocco Lite - Unable to create default folder
Instead of using 'PC studio' option while connecting, use 'media player' option for transferring the files. Check this option. If this does not work, try creating the default directory yourself manually using the phone and then try transferring the files.
Sep 19, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
K
Jul 24, 2009 | Epson Stylus NX400 InkJet Printer
Unable to scan.make sure there is enough space on the target disk
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Jan 24, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
ITunes won't open
Go to "Preferences" in iTunes and change the music folder location to the location on your new disk drive. Click the boxes as shown below:
image.tiff
Dec 28, 2008 | Apple iPhone Smartphone
Disk is Locked Error
If the My Music folder is in the wrong location or incorrectly assigned in the Windows registry, you may see one of the following error messages:
  • "The folder iTunes is on a locked disk or you do not have write permissions for this folder."
  • "The folder iTunes cannot be found or created and is required. The default location for this folder is inside the Music folder."
If you see one of the above errors, follow these steps to troubleshoot this:
  1. Verify the location of your Windows XP My Music folder. The default location for this folder is
    C:\Documents and Settings\username\My Documents\My Music
    If you do not have this folder at the default location and have not moved it to another location, consider creating one inside your My Documents folder.
  2. Download and install Tweak UI from the Microsoft PowerToys website at http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Note: This utility is for Windows XP only. Please review the system requirements before installing.
  3. Once you have installed Tweak UI, open it from the Start menu.
  4. In the column on the left, click on the plus symbol (+) next to My Computer and select Special Folders. ht1866_01.jpg
  5. In the right pane on the Folderlist, click My Music.
  6. Click the Change Location button. You may see a warning message appear with precautions for changing this setting; after reviewing the message, click Yes. ht1866_02.jpg
  7. In the resulting window, browse for the My Music folder as described in step 1, and click OK. ht1866_03.jpg
  8. Reinstall or open iTunes.
Oct 13, 2008 | Apple iTunes
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
Epson Stylus NX400 InkJet Printer Logo
255 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
