Question about Aloha Housewares (93645) Ceiling Fan
Need help with electrical on my ceiling fan now please
  • spleef160 Aug 22, 2010
    i have a aloha ceiling fan model#28004 with remote and light kit. there is 1 black wire and 1 red(i think)wireconected with a wire nut, there is also 2 white wires and 1 black wire. the instructions say to the fan motor white wire to the house white(neutral)wire with a wire nut. which house white wire? is the second white house wire for the remote if not then what? thanks scott gillum
  • 6,993 Answers
what's actually wrong with your ceiling fan? Let me know precisely the problem so that I can proffer an accurate solution to your problem.
I look forward to your reply.
Bye for now.
Posted on Aug 22, 2010
  • Walesarumi
    Walesarumi Aug 22, 2010
    there are two wires that should come from the wall, Positive (Red) and Negative (Black). There for, two wire (positive and negative should be coming out of the fan into the wall since the electricity from the wall is what's going to power the fan.
    The second white wire is not for the remote. The remote already has a sensor, that is connected to the fan engine by the manufacturer.
    Follow the fan instruction carefully and strictly. You should not be misled my so doing.
    Good luck.
Wobbles......5 ceiling fans
Several things can cause a ceiling fan to wobble. The most of common of which is loose screws in the fan blade irons , that attach to the fan's motor. Just one loose screw can cause significant wobble and at times, an annoying noise. The other, which is more serious, is that the plastic ball on the top end of the down rod, that attaches to the electrical outlet bracket, is improperly installed. It generally has a groove in it, that must be installed so that it fits over the tang in the bracket. The tang keeps the ball in place. To inspect it, you will need to loosen the screw on the ceiling cowl, so that it slides down the down rod. If the ball is not resting in the bracket properly, lift the fan up by the down rod and put the plastic ball in the proper position. Be sure the wall switch for each fan you work on is turned OFF, before attempting in inspection or repair.
While you're at it, make sure the ceiling/electrical box bracket is tight to the the ceiling and is level,
Hope this helped you troubleshoot and solve the wobbly problem. Please let me know. Thanks.
Jun 01, 2011 | Heating & Cooling
Installed a Casa Vieja Habitat Ceiling Fan today, the light works but the ceiling fan does not. Please help solve this problem! Thanks!
Check main line electrical wiring connection where it is connected and the switch electrical connection of the ceiling fun.
May 29, 2011 | Casa Vieja Habitat 44" Brushed Nickel...
I need a new one. Where can I purchase one?
Hi Debbie,
Here's a website with one available: http://electrical.hardwarestore.com/13-37-fan-control-switches/three-speed-ceiling-fan-switch--610039.aspx
Hope this helps. Please provide a vote as it helps me keep my rating here.
Thanks,
Handie Andie
May 01, 2011 | Westinghouse Electric Westinghouse...
I just need to know how to install this in an old house to replace a ceiling fixture and install a ceiling fan without having to make a huge hole in my ceiling. I can't find any instructions on the model...
If you're trying to replace a light fixture with a ceiling fan. The most important thing is to make sure that the electrical box in the ceiling can support the weight and momentum of a ceiling fan. If it's an old house, as you say, I suspect it's not. However, there are support kit, that you can but from most home centers, that will install without having to make a "huge hole" in your ceiling. If you have an attic above this room, accessing and beefing up the support of the electrical box would not be difficult. If you don't have that luxury, then the support kit is your best solution, as you don't need to have access to an attic above.
As far as the Model # 22200 is concerned ... Since you didn't mention what it was, I don't have a clue.
In any event, I hope this helps you in installing the ceiling fan. Please let me know and if you would please rate my response to you. Thank you!
Mar 25, 2011 | Heating & Cooling
My hunter fan is not working. the remote has a new battery however it will not turn the fan on or off and it will not turn the light on or off. the chain on the fan will only work the light. the fan...
It sounds that fan use to work and lights and you did correct thing by changing battery. I've had this problem and it just needs the reciever replaced. Reciever is located at electrical connection in ceiling. Just buy a new universal wireless remote and reciever at any home depot. if dont fill safe doing this task should call an electician to do job or someone with electrical skills.
Aug 13, 2010 | Hunter Ceiling Fan Light Remote Control
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Does the blue wires connect to the black or white wires? I cannot find the instruction booklet. Thanks
Hi, At the fan you'll have a black wire, blue wire, green wire and white wire.
In the ceiling you'll have a black wire, a white wire, and a bare copper wire. If you are using the same wall switch to turn on all of the power to the fan AND the light, connect as follows:
White at ceiling to white from fan
Black at ceiling to black and blue together from fan.
Bare copper wire at ceiling to green wire from fan.
When connected like this, the main power is from the switch, and the fan and light may be set by the pull switches on the fan.
Best regards, --W/D-- Please feel free to rate this solution... thanx!
Aug 03, 2009 | Casa Vieja Endeavor Cherry Ceiling Fan
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Electrical box not working
unfortunately it sounds like the main electic wire is shorted out. Not the one to your fan, but the one that provides the power supply FOR the fan. The only way i know to fix this is to get an electrician. I am certain the wire needs replacing.
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Can you please tell me how to install my Heritage ceiling fan?
Its really easy but you need to be safe, make sure all circuits are off to the outlets you are working on. Usually everything is color coated black goes with black (hot), white goes with white, ground goes with green or copper make sure you use electrical tape to tape up, then assemble from there using istructions. Hope this helps
Nov 17, 2008 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Aloha Housewares (93645) Ceiling Fan Logo
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
