Question about Sony Audio Players & Recorders
Turned off one day out of nowhere, screen turns on , looks like it wants to load for a while and then turns off! hit reset button on back and does same as above! sony walkman mp3 player model #NWZ- S545
  • Sony Master
  • 4,924 Answers
If ti has a charger or is charging from the usb ..try to open it with the charger or the charging source plugged..if it does open it means that the batteries are dead and need a new one cause it either do not charge anymore or do not hold the juice for some reason ...it may also be in short from some shock ..cause from what you explained it seams not to have any problems but just not enough power to boot up...
Posted on Aug 22, 2010
How do I reset day on my Canon Rebel t3? Some how it is off by one day.
Which day ? Don't forget that April 11 1954 was the most boring day in history.
Apr 26, 2017 | Canon Cameras
Samsung blu-ray won't load or eject
Someone is going to have to open it and look to see if the disc inside is out of position or jammed in some way----sometimes you can gently move it a little back into the position where it will eject the disc--which could be your entire issue.
May 28, 2012 | Televison & Video
I got a clarion vz409 car stereo an it locked completely
I just had the EXACT same problem, and 5 hours searching on the web got me nowhere. I set the lockout code, but it will not unlock, and now its locked up. then I called clarion. Turn the deck on with the screen out, then hold the power and play button to bring back up the password screen. Default is 0000 but if that does not work, enter 4356 and it will Unlock!
Aug 19, 2010 | Car Audio & Video
Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
Blank Screen on Garmin C330
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 | Watches
GPX player just showing a blue screen
IM NOT SURE WITH THE ERROR THATS WHAT IM TRYING TO FIX ON MINE!
BUT JUST HIT THE RESET BUTTON ON BACK IT SHOULD TURN OFF
Apr 23, 2008 | GPX MW3837 MP3 Player
Truck dvd player concept/pronto
Does it possibly have a reset button you could press with a paperclip? If not, try disconnecting the constant power wire for ....let's say an hour, and hooking it back up.
Nov 28, 2007 | Concept Slot Load Half-Din DVD Player Car...
How to unfreeze mp3 player
We have a toshiba gigabeat f20. today it worked fine, listened to it for hoursbefore turning it off. turned it on within a hour to play it and got a blank screen. nothing in the environment could have caused this. battery had been replaced a week before. so, took the case off to opened it and take a look. realized that one of the plug ins for the screen had come loose or slightly lifted inside. it did not totally unplug, just not pressed down tight. pushed it back in. put the case back on. hit the power button and it's back on, nothing that had been previously loaded was lost.
Nov 13, 2007 | Audio Players & Recorders
41 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
