Question about Admiral 32 cu. ft. Washer
My washer stops in the rinse cycle and sometimes in the begining of the wash cycle again
  • Admiral Master
  • 909 Answers
Not exactly easy to determine. Must check a few things first. 1) Does the timer stop at exactly the same places everytime when it stops? Make a mark at the place it stops and restart the program a few times. When it does stop, note if it is always at those marked positions. If so, the timer needs to be replaced. If the stopping positions on the timer are in the middle of washing and especially the spin, then the motor is defective.(the internal overload/overtemp) protection is activated,.
Posted on Aug 22, 2010
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
How to replace timer on KAWS850LQ0
The buzzing occurs, I turn the washer off, leave it alone for an hour or so, then I come back and begin the wash cycle from the beginning and sometimes it will totally complete the cycle. A couple of times it has just stop at the rinse cycle again. Then I try this same process over again.
Thanks for any help you can provide.
Increase Engine Horse Power.
Jun 02, 2012 | KitchenAid Washing Machines
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
I had troubles with my washer going through a cycle and stopping when it got to the rinse cycle. I put in a new timer, the machine worked great through part of a cycle but again quit just at the rinse...
Verify that BOTH hoses are hooked up to the correct water inlet and they are TURNED ON and FLOWING. Your condition acts like hoses are reversed, and the hot (cold actually) is turned off, that will cause the machine to stop on the rinse cycle....
Mar 04, 2011 | Roper RAS6233KQ Top Load Washer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Admiral 32 cu. ft. Washer Logo
176 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
