Question about Mitsubishi HS-U570 VCR
It ejects the tape immediately...and then it powers off.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Older VCR--I have one like it. You need to remove top cover and bottom shield, look for one of the belts to be either broken or off.
There are places on the net where you can buy a belt kit, includes all belts and most are easy to replace--they get old and sloppy with age.
If this has helped you rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 22, 2010
I concur with SD Tech: one common cause is a worn belt that has become too loose due to age. One of my Mitsubishi VCRs was exhibiting this exact same problem: insert tape, it gets ejected right away.
The belt I had to replace is the one that pulls tape out of the cassette when the cassette has been fully loaded into its final position. The belt is usually on the bottom of the drive chassis.
Posted on Jun 08, 2016
    Scholar:
  • 122 Answers
Is the tape fully re winded? Check the tape to ensure it is not hung up, turn the tape manually to see if you are able to get it to move. It is possible the tape could be hung and therefore the VCR can not turn it and assumes the tape is at the end and ejects/turns off in this case.
If that is not the case, are you able to put the tape in and quickly re-wind or fast-forward with out the VCR acting up? If so, try to re-wind or fast-forward it and if it does "while the tape is playing....and showing picture on the screen" then continue to push play and see if that has any effect.
If not, then most likely your VCR has become faulty.
Hope that helps.
Got a mitsub Hs-u430 vcr.Pluged in & immediately starts eject.Does twice then stop.Only halfway eject.Does with no tape in.Took cover off & help tape in.Push any button it does same all over.
Disc loading mechanism fault. Contact any service technician. The mechanism should be taken out from the set, for repair. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 26, 2016 | Televison & Video
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
The tape ejects immediately after inserting tape
your m-chassis has a problem with it and when we get these we replace the chassis and adjust them you should send to canon for repair or a qualified tech. sorry
Dec 01, 2007 | Canon ES8200V Hi-8 Analog Camcorder
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Televison & Video Logo
481 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
