Question about Maytag MER5530 Electric Kitchen Range
My oven works,but it won't get up to the right temputaure only 100
  • 1,998 Answers
Check your element when you turn on your oven also you can do a continuity test to assure that there are no break spots in the element the next thing to check would be your oven tempreture sensor usually small metal rod along top with two wires hooked through the back wall of the oven if you look in your manual should give you for a spec and you can do an ohms test on the sensor if the sensor fails from what the spec states replace the sensor when checking the element make sure the element glows red other then this you would have to go into the back panel of your oven and do some power tests and comparing that to your tech sheet that the write amount of power is going to the right places check element and temp sensor first please remember to rank how this opinion has helped in your appliance situation and if there are any futher questions please message me back have a great day
rickead1
Posted on Aug 22, 2010
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
Oven won't ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 05, 2011 | Whirlpool Ovens
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
heatman101
Jul 03, 2011 | Microwave Ovens
Turn it on at 350degrees it won' ignite and eat but will work on boiler
Oven not Working or
Oven not Heating
heatman101
Jan 24, 2011 | Ovens
Ovens won,t function, no spark or gas but gas hobs work fine
heatman101
Dec 30, 2010 | Rangemaster 110 (Gas) Kitchen Range
Not heating stays at 100
Oven not Working or
Oven not Heating
heatman101
Dec 17, 2010 | GE JGRS14 Gas Single Oven
MY KENMORE OVEN WON'T HEAT UP! What do I do? Everything else works but the digital temperature just stays at 100!
heatman101
Oct 13, 2010 | Ovens
The oven will not come on. The igniter doesn't seem to be working
my oven won't work when I turn it to 450 it only goes to 100 and won't heat. Can you give me a solution to fix it
Thank you
Jul 24, 2010 | Tappan TGF363 Gas Kitchen Range
Maytag MER5530 Electric Kitchen Range Logo
71 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
