Question about Mitsubishi WS-55613 55" Rear Projection HDTV
I just bought this tv ws-55613 from a friend, when I looked at it i hooked up a dvd player and it worked great.after igot it home, i hooked it dish network. It worked fine until i started to play around with the remote, now it says there is no signal and all i get is blue screen. I even tried to hook it up through input with rca cables still nothing. I no i am getta signal because i can hook up any tv and it works fine. please help!!
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This is 2003 model and does have a hard reset. It will return set to as it was when new in box, on air band on channel three, most likely you did something with remote that changed something.
I am in California and can tell you how to with the set on with the Mitsubishi remote enter the OPTION MENU AND RESET IT.
SD TECH (in San Diego)
Posted on Aug 22, 2010
  • Mike Perry Aug 22, 2010
    yes please send me the info.
  • SD Tech
    SD Tech Aug 22, 2010
    With the set on and using the Mitsubishi remote hit : menu, 0,3,7,0 and enter
    Highlight with remote either restore or reset--different words are used, it is usually first item on list when you call up the option menu.
    SD TECH---let me know what happens.
  • 122 Answers
Try changing the INPUT for the TV threw the Menu or there should be an INPUT button on your remote. Video 1/2/3/4, LINE, HDMI....
Hope that helps.
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55613 55 color out
the problem is on the cables , look on the back of the cable box , if it is hd box the on ly thing you need to do is put the cables base on there colors green with green , red and blue , the other 2 are for video , but if it is normal box just put the yellow color with yelow on your box to your tv and the other to are audio
Jan 27, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Model # ws-55613, a short time after the tv turns on there are wavy vertical lines that wont go away. if i turn off the tv and restart it will work for a short time and wavy lines will reappear.
The WS Mitsubishi has a known problem with the Power Supply electrolytic capacitors and the electrolytic caps on the DM board. See my tip at for more detailed information. The problem you are describing would be the first part of the known problem. There are several repair/replacement choices listed in my tip.
Thanks for using FixYa and for the great rating.
Jun 16, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
Mar 29, 2009 | Audio Players & Recorders
No picture from Home Theater/ DVD player... only sound
Have you checked to see if your t.v remote has an input selection button ? If it does than just scroll through the inputs and see if this works.
Jan 31, 2009 | Audio Players & Recorders
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Connecting an a/v receiver to a Dish network receiver
DO you have manuals for all the units listed?
If not , try the Samsung consumer site.
It would take me quite a while to figure out your situation even with manuals and I have a business to run besides.
Also, ask some questions of Tech Support at Samsung..Let them KNOW how much you spent on their stuff.
God bless,
Jul 07, 2008 | Televison & Video
Hooked up don't work
Hook the DVD Combo unit to the Video input of the TV. Not through your Dish Box. Then to View the DVD/VCR, switch the TV to the Video Input. Good Luck and have a great weekend
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Symphonic WF803 DVD Player/VCR
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
261 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
