Question about Remington WPG-250 Hair Trimmer
I need Guidance on opening the case up to check/replace battery. This is a Remington WPG-250 and doesn't have any screws on the outside.
There are no screws holding this together only 8 locking plastic clipbs (4 on each side). To open I started near the battery charger end and used a flat tip screwdriver to gently pry open the case. Repeat on the other side. Unit has 2 Sanyo NIMH AAA batteries (welded tabs in series). I can't determine if these are regular NIMHs or enloops.
Posted on Nov 06, 2010
Charger cable for remmington pg-400
You will find the charger at shaveroutlet.com using the link below
http://shaveroutlet.com/remington-charging-cord-for-pg-250-and-wpg-250.html
Jun 22, 2014 | Remington High Precision PG400 7in1...
Opening a remmington ms2 150 or ms2 300 razor to replace the batteries
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
To open the shaver you will need to gently pry off the rubberized grip on the front of the shaver. You can then access and remove two screws near the bottom. You will also need to loosen the flat metal clip plate at the top that is under the cutters. Once this is done, you can open the shaver and access the batteries
Jun 15, 2011 | Remington Health & Beauty
Remington Electric Shaver..How do I disassemble a Model XLR 900. 8BF2-1C. I want to replace the battery.
Unfortunately these rechargeable razors are not designed to be easily serviced by the home user.
Changing the battery will definitely involve a bit of searching for the multiple screws which hold the case together and then disassembling the case to access the battery compartment. Just watch out for any screws which may be hiding under the rubber padding pieces. You will then likely be required to desolder the old battery out and then resolder your new battery back into place.
Here is a link to a site which describes the various methods for disassembling battery powered shavers:
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Here is a link to a replacement battery available for your model:
http://www.batteryweb.com/cordlessrazordetail.cfm?ID=238
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
May 14, 2011 | Health & Beauty
Hello, How do I change the battery on the Remington TF300 shaver? and I don't know how to open the case to remove the old battery.
Remove the foil assembly and cutters. You will find 2 screws on the back near the top. Remove screws and you can then pry the front half of case off. You will then be able to access the batteries. There are two batteries connected end to end. You will find replacements at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Sep 25, 2010 | Remington Health & Beauty
I'm looking for a charger for remington model wpg-250
i was able to find the charger on the remington store. so i purchased it. problem solved. thanks
Sep 05, 2009 | Remington Health & Beauty
I need to replace batteries in Remington wdf 3500
Have just opened the same model -
First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
Dec 22, 2008 | Remington Smooth and Silky WDF-3500 Hair...
Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Aug 24, 2008 | Remington MS2-250
Remington hc-353
I have the above hair trimmer and batteries no longer hold charge. Take off the trimmer mechanism, that is the two large screws. Then unscrew the screw under plastic button, get flat bladed screwdriver and prise apart the two sections, they just clip together with plastic lugs at ai sides of the case. battery replacement, ehen you open you will see three batteries that have been soldered together. Have not found any easy way of replacing batteries at moment, still working on that one. Good luck Tony B
Jun 28, 2008 | Intermec CN3
Replacing the battery
Download the user manual - it has battery removal instructions ----
http://safemanuals.com/user-guide-instructions-owner-manual/REMINGTON/MS3-1000
Nov 28, 2007 | Remington MicroScreen 3-3000 Electric...
Remington WPG-250 Hair Trimmer Logo
332 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
