Question about Frigidaire FEF376 Electric Kitchen Range
Door won't unlock after attempting the self clean. Self clean failed
The model number is FEF369C6SD. We attempted the self clean, it locked and then made a clicking sound and then displayed F3. Now we can't get it to unlock. Is there a way to reset?
  • 290 Answers
Usually an F3 code means the temp sensor has failed. The oven control thinks the oven is to hot to open. You may have a failed control, but I would try replacing the sensor first.
Post back with any questions. Have been very busy at work and have not been online answering questions much lately but will answer back when I can.
Thanks, Mike
Posted on May 07, 2008
F93 code (door not locking) tried to 'reprogram' by leaving unplugged for an hour, worsened the situation. Now when repowering, it immediately attempts to lock the door, obviously unsuccessfully and throws...
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&^%$
Mar 16, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
unplug the range.
wait 1 minute.
wait 2 minutes.
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F9 code on unit. Oven door locked
Yes, the error code F9 means that the door lock circuit is faulty and should be checked and replaced by a technician. I can supply you with a part number if your able to locate the model number. Which can be found usually on the inside of the pots and pans drawer at the bottom, OR on the back area or the stove. Usually will begin with letters followed by numbers. Hope this helps
Thanks
Jan 02, 2010 | Ovens
Oven door is locked shut. How do we get it to
Try cutting the power to it. ALSO push in to relieve the tension on the latch while attempting to open it.
Oct 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Self Cleaning
unplug the range.
wait 1 minute.
wait 2 minutes.
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire FEF376 Electric Kitchen Range Logo
138 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
