Mitsubishi vs55601 big screen tv The problem is when I turn on the power I can hear a click and a dim light flash on the screen but then It click right off. How can I fix this problem and what are the parts I should buy to fix it. Thank You
    President:
  • 2,712 Answers
Hello buisamson,
Try a hard reset first..Unplug all connections from the TV, including mains. Wait for about an hour.Nowkeeping the power button pressed, plug in the TV to the mains.
If that did not work, it looks like you have a burnt out resistor or a faulty convergence IC, or bust capacitors. Most likely the regulator is bad because of bad capacitors or you have a faulty flyback or the auto transformer attached to it. (The click sound you hear is probably the flyback). Can't really say for sure with my long distance diagnosis.
However, one things for sure...if you do not have any solid state printed circuit board repair experience, I'm afraid the best advice I can offer would be to call in a pro to assist you in this repair.
If you wish, you can contact Mitsubishi Electronics Customer Support at (800) 332-2119.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 04, 2008
I have a 46" Samsung LCD tv that won't turn on. When I press the power button you can hear the chime sound it usually makes and you can hear the relay click and the screen flashes quickly then goes bl
sounds like you have a back light problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flash light on the screen. If you see the faint picture on the screen, you have a back light problem. You could either have a shorted inverter that is pulling down the 24vdc line, a blown CCFL back lamp, a high voltage short (arcing) from one of the inverter outputs, or a faulty 24vdc power supply
Dec 09, 2012 | Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi vs55601 big screen tv. The proplem is when I turn it on I hear the click and a light flash on the screen but then it click rigt off. How do I fix this problem
It is an internal problem. In my opinion, i wouldnt handle this specific problem myself, but take it to a tv repair specialist. Fisrt, i would follow the trouble shooting manual, then all customer support.
May 04, 2008 | Televison & Video
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My big screen tv
Those are the two 5amp pico fuses that go out when the convergenec Ics go out on a mitsubishi. You can get the ICs and pico fuses at the following link. If youre not sure which ICs you need leave them a email with your model nuber.Heres the link
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Televison & Video
Lamp Light flashing Yellow
double check the lamp.make shure the 2 wires were installed correctly.Also check the plug inside the tv where the lamp plugs in.They have a nasty habbit of coming loose.
Jul 17, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Smoking tv!!!
Good Day, gongora326;
It sounds like the TV has some type of short in the power or high voltage circuits.
I would recommend that you call a factory authorized service company to come to your home and give you an estimate.
I hope you take my advice, good luck, big IRISH.
Jul 08, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
