When i restsrted my labtop it gives me this messege(/windows/system32/config/system)file is missing or corrupted
    Problem Solver:
  • 10 Answers
Your registry is thoroughly messed up. You need to reinstall Windows.
Posted on Aug 22, 2010
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Tip
How To Fixed Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG
If you get the error:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. cd \windows\system32\config
  6. Depending on which section was corrupted:
    ren software software.bad or ren system system.bad
  7. Depending on which section was corrupted
    copy \windows\repair\system
    copy \windows\repair\software
  8. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
File:\windows\system32\config\system file is missing or corrupt laptop : sony vaio
boot you computer using OS CD and at first screen use recovery console command prompt
at command prompt
wait for 10 second and the enter your administrator password
then go to c:\windows\system32\repair
the type copy system c:\windows\system32\config
press y to overright file
and restart your computer
Nov 23, 2010 | Computers & Internet
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
Windows/system32/config/system is corrupt
One of following will work:
http://www.help2go.com/Tutorials/Windows/C:%5Cwindows%5Csystem32%5Cconfig%5Csystem_missing_or_corrupt.html
http://www.techsupportforum.com/microsoft-support/windows-xp-support/312090-windows-system32-config-system-missing-corrupt-files.html
http://en.kioskea.net/forum/affich-22815-windows-system32-config-system-is-corrupt
http://support.microsoft.com/kb/307545
Mar 20, 2009 | Microsoft Windows 2000 Professional for PC
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
