Question about Maytag Dryers
Dryer worked earlier for one load and stopped working after that. What could be the problem? I checked the machine and it has electricity because light inside still comes on???
  • 36 Answers
Can you provide me with a model number?
Posted on Aug 22, 2010
How do I fix dryer that stopped working?
Check the little button that the door pushes in when you close the door (door switch).
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
My dryer stopped heating. How can I trobbleshoot?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 13, 2010 | Whirlpool LTE5243D Top Load Stacked...
Dryer stopped heating
heatman101
Nov 08, 2010 | GE WSM2420T Top Load Stacked Washer /...
My dryer has stopped heating completely. Worked fine for six years and stopped heating four days ago.
heatman101
Nov 06, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
Dryer just stop working
check fuse, but this sounds more like an electrical problem on the motor, depending on how long you have had the dryer and useage it probably be the bushes which can be replaced by an enginneer.
May 12, 2009 | General Electric WPDH8800J Front Load...
No heat in dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
98uit
Feb 05, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Dryer will not work, has electrical power, but does not light up
look for a fuse mounted beside the heater element. small black with 2 white wires attached, open and the dryer don work, but wait thers more... look into the blower assembly for blockage of lint or loose blower.
Jan 30, 2009 | Maytag MDE9700AYM Electric Dryer
Dryer is not heating air
Sounds like the heating element or coil is out, but it could also be the board to. At any rate, if your not getting any heat what so ever, its more than likely electrical and its best to take it in. If it gets some kind of heat, then you might try cleaning out your dryer vents really good, and also in the dryer. Hope this helps.
Jan 02, 2009 | Maytag SDE3606A Electric Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
