Question about Westell Wirespeed LiteLine 6000 Modem
Need password for Westell DSL - Westell Wirespeed LiteLine 6000 Modem
  • 490 Answers
The default username is usually ADMIN, and the default password is PASSWORD. If it has been changed, you can reset using pinhole reset on bottom or back or just unplug it for a few seconds.
Hope this gets you up and running:)
Posted on Aug 22, 2010
2 Suggested Answers
Panth3on
  • 71 Answers
SOURCE: Connect 2 PCs to Westell 6100 DSL modem
well depends on if you want to hookup wirelessly with one or not. If the modem has a USB connection as well as ethernet, then you can hook up 1 computer to usb and 1 to ethernet with no problems. If you do want a wireless hookup then yes, you need a wireless router. I would just go with a router because of the convenience of being able to go wireless if you decide to. I would suggest a Linksys WRT-54GL with a 3rd party firmware (DD,-WRT, Tomato, etc.) Hope this helps.
Posted on Sep 14, 2007
I reset my router but what is new password is my rougter?
here is the manual - there should be non but if this is a device from a telecom, it will be their default password and username.
http://www.westell.com/docs/support-documents/327w11_06_ug.pdf
Apr 12, 2014 | Westell Versalink 327w Wireless Modem...
Need password for westell versalink ADSL2
Check on the bottom of the router and locate where the MAC ID is and try that.
Mar 22, 2012 | Westell Wirespeed VersaLink...
My router will work as a 4 port connect but no software to config for my xp pro sp3. help w dsl.?
You do NOT need software to configure the Westell- it is configured through a web-browser interface. Here's how to access the westell: Go to start > run> type cmd. Press enter. That will bring up a command prompt. Type IPCONFIG /ALL and press enter. What you are looking for is the default gateway. Normally it should be 192.168.1.1
Next open a web browser (internet explorer, firefox, chrome, safari, etc) and in the address bar (NOT THE SEARCH BAR!) type 192.168.1.1 (or whatever you saw for Default Gateway when you ran IPCONFIG)
You should get a box asking for user name and password- by default those are "admin" and "password" respectively.
That should log you into the Versalink, where you can modify how it connects (for instance, setting the DSL username and password, or DHCP, or static IP routing information), the wireless features, etc.
Oct 01, 2010 | Westell Wirespeed VersaLink...
How to set a password for westell 327w dsl
the best way to describe what you need to do is to check the device manual. the section is 12.4.2 WIRELESS SECURITY, here's the manual
you should also check and setup a new password for your router configuration page, section 14.3.
hope that helps!
Dec 26, 2009 | Westell Wirespeed VersaLink...
Can't connect my wrt56gs to my westell 6100 modem, could you please help?
You are using westell modem that means your internet service provider must be DSL.You will need to make sure that your computer is able to go online when connected to the modem. that will decide the type of ISP connection.
Click Here for more info on how to set up the router.
Oct 18, 2009 | Linksys Wireless-G WRT54G Router
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
I clean up my pc and now im trying to install the westell and i dont know how
You will need your username and password to configure your DSL. The easiest way is to contact your ISP heldesk and have them reprovison your modem.
Jun 20, 2009 | AT&T High Speed DSL Modem
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
Setup Wireless Router to Westell 6100 modem
Your Wireless router should have come with a CD. Insert the CD into your computer and follow it step by step. If it did not come with it here is a basic wiring setup.
From wall jack to Westell modem, From modem to uplink port on Max G router.
Reboot Westell modem. T
Everything should auto-configure unless you need a username and password for your DLS. If so you will need to program this into your router.
Dec 21, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed LiteLine 6000 Modem Logo
131 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
