Question about Garmin iQue 3600 GPS Receiver
Ique 3600 The unit only works when i plug it in to the wall. Every time it is plugged in, you have to reset the stylus pen settings, time and date. why doesn't work when I just want to use it without the wall plug? is there a battery somewhere that is bad. This unit is BRAND NEW right out of the box. It has been in the closet a couple years. I charged it up for 24 hrs, but still nothing. Also, the card slot appears to have a fake plastic SD card in it. Am I supposed to put something in there as well? The book and directions are absolutely horrible! Thanks
  • 3 Answers
Even new, the battery is a 3600 sore spot.
If it has been left uncharged for two years, it is probably garbage.
I got a new and improved one for mine for about 30 bucks.
Try BraunOni, Eruope, I think, but the service was great.
Posted on May 06, 2008
IQue 3600 won't respond properly to stylus. Responds if you touch one item down the lists. Example, to OK something, you have to touch right below the OK. It just recently started this, Maps display...
I solved the problem by re-calibrating the screen. Go to the home icon on the screenn tap preferences, date and time, then tap digitizer. Then follow the prompts and tap exactly on the target Xs.
Thanks!
Oct 01, 2009 | Garmin iQue 3600 GPS Receiver
Data card and frozen screen
HI,
Please reset it and your problem will be solved.
Jul 15, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 not working
Been there. If the unit will not reset with the hole in the back poke you need to disconnect and reconnect the battery. Use a small torx screw driver for the four screws in the corners. Gently split the back case off by the thumbwheel and pivot it around. the battery connector is a small white connector in the lower left hand corner. Be careful of the power switch, ir lamp cover, and plug gasket since when you open the case they sometimes make a break for freedom.
May 08, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
I have a ique 3600 and was working fine until I plugged in the ac adapter to the bottom of the unit. It won't turn on. I did a soft reset and now I get a flashing Palm Software screen. I even tried a reset...
Mine has gone into the looping/flashing Palm Screen and then displays the hard reset do you want to erase everything. I fixed it by pushing the up button when it gave me the chance to delete everything and it fixed it.
Dec 20, 2008 | Garmin iQue 3600 GPS Receiver
Internal antenna works but can 't get external to work
Sounds like ext antennae is sick. Mine works 100% just by plugging into 3600
Aug 10, 2008 | Garmin iQue 3600 GPS Receiver
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Broken screen
The best solution, in my opinion, is to buy a unit being sold for parts or repair (making sure that the LCD display was working) and do the replacement that way.
That's what I'm doing because when I write with my stylus it doesn't recognize what I write.
Dec 17, 2007 | Garmin iQue 3600 GPS Receiver
My ique 3600 does not respond
Try resetting the unit and calibrate the screen. The problem is that the screen is not calibrated.
Nov 30, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
'Soft Reset' If that fails 'Hard Reset' while plugged into the mains! You will end up with an empty iQue but a HotSunc will re-intall
Mar 29, 2006 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
