Question about Delfield Freezer 6125XL-S
NOT GETTING COLD ENOUGH 25 DEGREES CLEANED
NOT GETTING COLD ENOUGH 25 DEGREES CLEANED CONDENSER DEFROST TIMER WORKING SUCTION PRESSURE HIGH
  • 3,740 Answers
High suction pressure is telling you there is a blockage in the coolant system usually. It most often occurs at the drier. If the drier is clogged it will cause the symptom you describe. This may sound crazy but take two wooden handles (hammers whatever) but WOOD and strike the drier simultaniously. (I.e at the same tame with the handles. Don't be afraid to give it a good whack.. just don't dent it or the lines. It may or may not snap out of it. Additionally the capillary tube can cause the exact same symptom. You have coolant flow.. just not enough.
You may sadly have to have to system bleed off (recaptured coolant) and purged until restriction vanishes with nitrogen if you can not find the current restriction. These can be real easy or a nightmare there is no in between.
Thanks for choosing FixYa.
Kelly
Posted on Aug 22, 2010
Ffbm 920w won't cool
It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
Mar 31, 2014 | Avanti FFBM921PS 9.2 cu. ft. Bottom...
Does not get cold enough
If refrigerant charge is ok, make sure that the evaporator coil is not covered with ice. The latter serves as an insulator and will keep unit from achieving designed low temps. Remove ice by defrosting unit manually and then restarting unit. If ice continues to build up at alarming rate check for the tightness of door gaskets. If lots of moisture gets into unit, it will collect and freeze on coil. Also check to see that the defrost timer is not going on excessively. Those defrost cycles can raise internal temps by as much as 25 degrees; if the cycles come on prematurely and/or very often internal temps will be high.
Nov 16, 2013 | Kelvinator Freezers
Does it make sense that a frigidaire plhs67egsb3 refrigerator freezer could stop working simply from overloading? The compressor is running, the condenser coil was clean but the evaporator coil was frozen...
the defrost heater or thermostat circuitry is bad,you need to test both components,also the defrost timer control if the other parts test o.k..,the defrost tstat has to be below 32 degrees or it will test bad/open,when the evaporator coil gets iced up you cannot blow cold air through a solid block of ice,(NO air flow)means no cold air throughout the unit even with the evaporator fan running
Apr 12, 2011 | Frigidaire Freezer FFU1212D
I have an AHT Salzburg chest freezer and it's stuck in "chilling" mode and not getting cold enough to freeze anything. It's a commercial freezer and says it has chilling and freezing modes but how do I get...
pull the plug and let it defrost. ck the drain for water. it maybe pluged. after 2 to 4 hrs. plug it back in and set the temp. to -10 degrees f . fill small dish or bowl with water and see how long it take to freez. if it takes longer then 4 hrs you may need freon or have a compreesor problem, or defrost timer .
Aug 23, 2010 | True 31 cu. ft. / 878 liter Commercial...
Commercial freezer (Randall) with a Ranco thermostat, not cooling
clean condenser? is evaporator free of ice? may need defrosting or low on freon. Tom
Jun 30, 2009 | Freezers
Evap fans not turning on
If this is a commercial unit, you're too low on refrigerant (freon). Freezer should be about a minus 10 degrees for the evap and high side is ambient converted to a psi for the type of refrigerant that is in the system plus 25-30 psi.
The evap fans will not come on because the evap is not cold enough.
Hope this helps and good luck.
Apr 09, 2009 | Freezers
Master built 2 door freezer model BLG-48HD serial 016254 still in warry. How do you tell how long defrost and time it goes into defrost? Also box won't pull down to temp, high alarm goes off. temp 25 in...
most units are on a timed defrost that occurs at different times so finding the exact time will be hard but defrost times are about 30 minutes. from the pressures you posted I'm thinking that the condenser fan is not running or the condenser itself is plugged up with dust. (i'm not very familiar with r404 but for most other refrigerants the hi side pressure is really hi). if its still in warranty you would be better off to call your service company after your sure the condenser itself is clean to prevent a charge for impproper maintanence. thanks peyton
Mar 06, 2009 | Freezers
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Delfield Freezer 6125XL-S Logo
138 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Tom Donaldson
Level 1 Expert
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
