Question about Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
WRT54GP2A-AT - Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
I'm trying to connect my router. Why is the power light on my Linksys router blinking
Please reset the router by pressing the router reset button on the back of the router for 30 seconds if the lights still blink this should be a hardware failure
Jun 20, 2012 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Smartbook
You can go to command prompt window and type ipconfig to get the ip address on the computer.
May 25, 2012 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
I want ip
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on lan setting and note down ip address of router. if you want ip address from router then enable DHCP in router then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Oct 05, 2010 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
When i set up the router i gave a password but
If you want to change the password to access the router you can open your browser and put in the address 192.168.1.1 (unless you changed it) and press enter. You should be prompted for a user name and password. Leave the user name section blank and put in the password for the router. Once you have logged into the router successfully, you will see the Administration tab. Click on it and you will be able to change the router password. Save the changed and close the browser window when you are finished.
If you need to change the Wireless Internet password, you can click on the Wireless tab, go to Wireless security and change the passphrase there too.
I hope this helped. Thanks for using FixYa.com!!
Apr 18, 2010 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
It shows a excelent connectionm wireless and shows a conection wired but dosen't let me load web pages
Either disconnect your wired connection or disable your wireless connection. Your computer doesn't know what device to use for your web browsing.
Oct 05, 2009 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
I cannot connect to the router, every time I try it gives me a Check_highjack.html page. Linksys 80211.g WRT54gp2a-AT
sounds like you might have a browser hijacker or a virus run antivirus software and spyware checks after that try again
Jun 12, 2009 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Obtain password for locked SPA device
Hold down the reset button in the back. hold it in for 30 sec.
it will reset to default settings. there is no way to get the password.
Jan 09, 2009 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
I cant register my cit310 on line
That's because you have not registered for site use. So your log in is not recognized,http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1115417027773&pagename=Linksys%2FCommon%2FVisitorWrapper.go here and on left tool bar at top make sure your country is shown go to support ..register.richardm69
Dec 17, 2008 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Voice_adminpage password?
connect ur pc through hard wired and open web page and type 192.168.15.1 hit enter and hope this is a voip vonage router and
user name : admin lower case
password : admin lower case
and click on administration and under neet that u can see voice and if u want to go through support login u need to contact vendor because the password will change everu 20 minutes and iam sure there is no voice login
rate me solved if its helps thx
Dec 04, 2007 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Linksys WRT54GP2A-AT Router (WRT54GP2AAT) Logo
71 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
