My F&P 6.5 kg top load washing machine will not fill with water. The wash cycle seems to start okay but no hot or cold water enters. The solenoids seem to be okay
  • 487 Answers
Ok. the most comon problem is the inlet filter in the machine. This is located where the hose connect. Disconnect hose and clean out the filters.
If this does not work check the pressure switch which is connected to the drum with a little hose. disconnect that hose and see if it will fill then. Check for current over your water inlet valve.
That are the things which can prevent you from starting the machine
Posted on May 04, 2008
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Washer only fills with hot water
Probably a bad water inlet valve. To verify, you would have to check continuity at the valve.
http://tclaundryrepair.com/home
Feb 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
