Question about Whirlpool GU2455XTS Built-in Dishwasher
Suddenly not getting dishes clean. Also drawers squeek when opening and closing
  • 36 Answers
If your dishes arnt getting cleaned anymore most likley your sump motor assy needs to be replaced and the squeaking is prolly the door cables. Ive enclosed the part numbers you would need. Whirlpool has a 5 year warrenty on the sump motor. So maby whirlpool could send it to you and you would just have to get someone to install it. Save yourself some money. I hope this helped you any questions feel free to ask.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-gu2455xts-%3d%3di1548391&PartID=1548391
Good Luck
Phillytech
A.S.A.P. APPLIANCE REPAIRS LLC
Posted on Aug 22, 2010
Tablet drawer
be sure to check the drawer that it is clean and not sticking. u can order the drawer from applainceparts.com and replace it if needed
Apr 06, 2014 | Hotpoint 24 in. DWF33 Built-in Dishwasher
I have a DS601 v2 dishwasher drawer that has suddenly stopped cleaning the dishes. The drain filter isn't completely emptying either. I've taken all the parts out and cleaned them bit this made no...
There are a few things that can cause this.
If there are no error messages being displayed during the cycle, the most common ones are:
1) Loose Impeller on the motor rotor. Check it by removing the drain filter, dish rack, spray arm and main wash filter (the giant stainless steel circular one), then twist the motor to the left and it should just pop out. If you hold the bottom of the motor in one and and the larger impeller on top freely spins, this is your problem.
2) Crack in the side of the spray arm. If the spray arm is separated, then the water pressure will being spraying sideways, rather than up to your dishes.
3) Too much fat or protein built up inside. This happens when you put too much eggs and milky stuff in there. Just run it for a cycle with detergent but no dishes. DO NOT use one of those dishwasher cleaner things in a dish drawer, they do more harm than good due to the fact that they are designed for a dishwasher with double the capacity of yours.
Mar 16, 2013 | Dishwashers
Suddenly my dishwasher is not getting the dishes really clean. Glasses have heavy fogging and are spotted.
Have you recently topped up the salt drawer?? if so, you may not have closed the top tightly... by not closing it really tight can make too much salt go into the cycle thus creating cloudy/dirty looking glassware. Hope this helps x
Jan 25, 2011 | Frigidaire Dishwashers
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Our hotpoint DWF33 Aquarius seems to be going through it's cycle normally but at the end of the program the dishes are not clean, the tab drawer has opened but the tab is still hole. and there is no steam...
i removed the drain cover in the bottom of the dish area ( near the salt fill cap )and cleaned it out. poured boiling water in and closed the machine and ran it with the hottest setting, empty.
this seams to have cured it
Oct 10, 2009 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Fisher & paykel top drawer stuck again
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Drawers Stuck
the lid acuators have been up dated(due to this problem) though i find it hard to beleive both are bad
Jan 06, 2008 | Fisher and Paykel 23 in. DD603H SS...
Whirlpool GU2455XTS Built-in Dishwasher Logo
204 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
