Question about Kato N Scale, Amtrak P42 Superliner Train Set
My N scale locomotive train just froze. I just bought it a few days ago. Why did it freeze up and how do I get it running again?
Thomas only runs on power track
PDF]EZ Command instructions.qxd - Bachmann Trains
www.bachmanntrains.com/.../EZ_Command_instru...
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
[PDF]5 Amp Power Booster - Bachmann Trains
www.bachmanntrains.com/.../449105-AMPInstructi...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
Jan 08, 2016 | Bachmann Ho Bachmann Thomas and Friends...
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Jan 08, 2014 | Lionel (31956) Thomas The Train Set
Locomotive moves then stops
If your locomotive continuously starts then stops, when prodded with hand/finger repeats process. Then most likely, first check your electric connection for a loose connection. If everything looks ok, check wheels on locomotive for dirty wheels, then check track for dirty track.
Nov 10, 2013 | Kato N Scale, Amtrak P42 Superliner Train...
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Want to sell my first generation Big Hauler G scale set. Pristine. In original box. Complete with extra track. How much is it worth?
The Generation 1 Locomotive, is of minimal value.
Best bet if you want to sell the set is to part it out and sell the cars separately.Locomotive, & tender w/rc transmitter ~ $15.00 - $25.00Cars ~ $20.00 - $25.00Track ~ $2.00 - $2.50 per section.If sold as a set, probably would be lucky to get ~ $50.00
Apr 03, 2012 | Bachmann Big Hauler Radio Controlled Train
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
Kato locomotive doesnt run. Goes for a short time with spray of contact cleaner then stops
That means that your track is dirty. Your locomotive is picking up dirt from the track, which builds up. on the wheels. Use a track cleaner NOT alcohol... the alcohol does leave a residue on the track after it dries.
Jan 10, 2010 | Kato N Scale, Amtrak P42 Superliner Train...
Remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
Dec 29, 2009 | Brio Remote Control Express Train
Kato N Scale, Amtrak P42 Superliner Train Set Logo
37 people viewed this question
Top Kato Toys Experts
ray gallant
Are you a Kato Toy Expert? Answer questions, earn points and help others
