Question about Sport & Outdoor - Others
I need a manual for a 2006 fleetwood morgan travel trailer and I cannot find one
mycharmingli
  • 389 Answers
SOURCE: Slide out will not slide it is out but will not
GO TO THE ELECTRICAL PANEL WHERE THE CIRCUIT BREAKERS ARE,ON MOST MODELS, THE DC INVERTER (12VOLT) IS BUILT TO THE AC (120 VOLT)BREAKER BOX.CHECK THE FUSES ON THE DC INVERTER SIDE(SHOULD LOOK LIKE AUTOMOTIVE FUSES) IF FUSES ARE GOOD,CHECK FOR PROBLEMS AT THE TRAVEL LIMIT SWITCH LOCATED SOMEWHERE AROUND THE TRACKS THAT THE SLIDE TRAVELS ON.SOMETIMES AFTER SITTING FOR A WHILE THE LIMIT SWITCH DO NOT MAKE PROPER CONTACT FROM AGE,USAGE, CORROSION,ECT.,EASY THING TO TRY IS MANUALLY MOVE THE ACTUATOR ON THE LIMIT SWITCH SEVERAL TIMES WITH YOUR HAND ,YOU SHOULD FEEL OR HEAR IT CLICK. THOUGH IT IS SELDOM THAT THE LIMIT SWITCH IS A PROBLEM,IF THE FUSES ARE ALL GOOD,THE ONLY THING LEFT IS THE SLIDE MOTOR WHICH CAN BE LOCATED UNDER THE TRAILER AROUND THE SLIDE TRACKS,UNPLUG THE WIRES,HAVE SOMEONE PUSH THE SWITCH WHILE SOMEONE CHECKS FOR VOLTAGE AT THE MOTOR,YOU SHOULD USE A TEST METER ABLE TO READ AND VERIFY 12 VOLTS DC.IF YOU HAVE 12 VOLTS DC WHEN BUTTON IS PUSHED,MOTOR MAY BE BAD,PLUG WIRES BACK TOGETHER,MOVE TO A SAFE PLACE AWAY FROM POTENTIAL PINCH POINTS AND PUSH THE BUTTON AGAIN.
THERE MAY BE A CHANCE OF BAD CONNECTION AT THE MOTOR PLUG.
I HOPE THIS IS NOT TOO CONFUSING,AND THE PROBLEM IS ONLY A FUSE BECAUSE A FUSE IS A MUCH SIMPLER,CHEAPER FIX.
BEST OF LUCK.
Posted on Nov 07, 2010
  • 35 Answers
SOURCE: We have a 2005 Fleetwood Wilderness travel
I am not an expert on this but try looking for your tank andsomewhere between the tank and hot water tank there should be valves(used for winterizing) one of these could be slightly closed. If thats not it I would suggest looking for a crimp in a line starting at the hot water tank.
Posted on Feb 03, 2011
SOURCE: We have a 2006 31
I do not have specific answer.
Open following links to identify product, download service guide and download manual for the different model numbers, plus parts list and other resources:
Page 3-4 of following manual shows switch settings for LP gas.
On-line manual can be word-searched for 'switch.'
This water heater has remote switch, which is the switch you are talking about. It also has limit switch and ECO (energy cut-off switch)
http://waterheatertimer.org/pdf/Atwood-installation-maintenance.pdf
http://waterheatertimer.org/pdf/Atwood-Water-Heater-Service-manual.pdf
http://waterheatertimer.org/Atwood-water-heater-resources.html
Posted on Jul 26, 2011
SOURCE: Need owner's manual on 2004 Terry Quantum Fleetwood Trailer
When I plug my terry I don't get power but I get power from my battery the power source work at the camp site but I'm not getting power can any help me
Posted on Sep 22, 2011
emissionwiz
  • 76164 Answers
SOURCE: NEED OWNERS MANUAL 2001 PROWLER TRAVEL TRAILER 255B
We have no owners manuals for any vehicle of this type. Sorry
Posted on May 01, 2012
On the out side of your rv, there should be a metal hinged panel that you open up to get to the backside of the water heater. usually about 16 in by 16 inches. On the inside it is usually under a sink, or bench you will have to figure it out from the outside first and you will know the general location on the inside.
Jul 13, 2017 | RVs
WIRING MANUAL FOR 1990 FLEETWOOD PROWLER TRAVEL TRAILER
well I do believe the possibility of you finding a manual for 26 year old trailer are not too good , but try this diagram its helped me out on some old ones before
https://www.etrailer.com/faq-wiring.aspx
Aug 09, 2016 | Cars & Trucks
What site can i get an 05 fleetwood terry travel trailor manual
search for that on Google either terry travel trailer manual or the manuufacturer's website
Mar 09, 2016 | Cars & Trucks
Manual for 2006 FLEETWOOD prowler camper
Even though Fleetwood no longer manufactures Travel Trailers you may still want to call Fleetwood RV Owner Relations at 1-800-322-8216 and see if they can help you out with locating a manual.
You could also try ebay and see if anyone is selling a manual.
You could try facebook for an rv community.
or try this link
http://www.rvingthemidwestconnection.com/manuals1990newer.htm
Oct 23, 2015 | Cars & Trucks
Sport & Outdoor - Others Logo
266 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
