Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My dog must've sat on the remote and now I cannot for the life of me get the green words "Video 3" to come off of the screen. Any suggestions?
  • 490 Answers
The tiny button marked INFO is usually the culprit. You could hit the INPUT or SOURCE button to change the message:)
Posted on Aug 22, 2010
My PS 3 comes on but no display on the TV. I've
Stupid question i know ,buut, have you pressed AV on your TV remote !!
Jul 16, 2012 | Sony Playstation 3 (PS3) Console
4.4 IR/UHF PRO only controls volume on tv, will not change channel
I've reviewed your post, carl_heflin, and would be happy to help with that! Below are just a few steps for you to go through to get that accomplished.
  1. Go to System Info screen.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
If you have any questions, just let me know and I'll look forward to speaking with you!
Sep 20, 2011 | DISH Network IR Remote Control
My control remote doesn't change channels. the sat button lights up in green and all i can do is change the volume.
Hi there! You may need to readdress the remote to the receiver. Just follow these quick steps to do so:
1. Access System Information screen and note the Remote Address
2. Hold SAT on the non-working remote until all lights on top turn on.
3. Enter a number between 1-15 and press #
4. Press record 3 times and the number should change.
Tommy Faust
DISH Network
Aug 11, 2010 | DISH Network IR Remote Control
I used the TV remote to change channels instead of using the new SAT remote and now I can't get the tv to work...all I see is fuzz. I followed instructions from handbook to "recover" etc...still no...
more info needed... if it is the tv 1 and you have a coax cable (screw on cable) the tv needs to be on channel 3 or 4 if you have it connected with rca cables (red, white, yellow) the tv will need to be on input (tv/video, input, video, source, on your tv remote) if it is a high def receiver and tv it will need to be on the input hdmi or component (component= y/pb/pr (green,blue,red)) if it is the tv2 (if the sat remote has a blue 2 at the bottom) the tv will need to be on channel 60 or 73 if your still getting snow check the cable connections and or replace the cable and make sure you have the green light lit on the front of the receiver box.
Nov 19, 2009 | DISH Network IR Remote Control
I accidently sat on remote for centrex t.v now all i have is a blue screen and a red padlock sign, how do i unlock
pls check hideen key on remot cantrol
try digit key [- - -] preesing 3 to 5 sec. and see key lock is off than re set preesing 3 to 5 sec and see on the screen tuning lock is off
or
lock key on remot cantrol pls. press 5 to 10 sec.and see the screen red padlock is opan or green then try remot cantroll any function use normaly
Oct 26, 2009 | Televison & Video
Sony dvp-ns425 player has the word VIDEO in upper right corner appear and disappear every 20 seconds or so. It is in the same green block letters as all the menu/control titles so I know it is from the dvd...
That word Video in green color could be TV's on-screen display as DVP-NS425 has another kind of on-screen display that has track info, time info etc in display.
Please press Display on TV remote to turn off that green color Video on-screen display at top right corner.
Thanks.
Sep 13, 2009 | Sony DVP-NS425P DVD Player
I have a dish network 211 receiver and the 1000.2 3 lnb dish - but I can't get the switch or lnbs to detect 129W. 110 - 119 are good to go but no 129. ???
Hi! I will be more than glad to assist you in this concern. Lets check your cable connection first if all is connected hand tight on the back of the receiver, check the sat in connection. once your done, press the menu button on the remote, that is located on the upper left of the remote, once you have the main menu, press 6,1,1 on the remote on it will go to point dish, select check switch on the point dish screen, that is on the upper right of the screen, once you select check switch, it will go to the installation summary, you will see port1-119-ok-1k.2, port2-ok-1k.2 port3-con-1k.2, select test on the butom of the screen, it will run a test up to 3 or 4, it depends on the status of the lnbf, once its done, it will show the whole screen of installation summary, port1-119-ok-1k.2, port2-110-ok-1k.2, port3-129-ok-1k.2, once you see these, the problem is fix and you need to select done and it will go back to the point dish, select done, it will show you an option on the screen, then press 0, 3 times on the remote to exist all the way out, it will go to a pic or it will show attention 015, let the progress fiish and let the programming download finish as well. that will fix the problem, just incase still no 129, please unplug the power of the box from the power outlet for 1minute, plug in then you will see attention 015, press the menu button again from the remote, once you see main menu, press on the remote, 6, 1, 3, check on the field g, 119-green, 110-green, 129-green, if you got 129-green, that fix the problem, in case there is no 129, please call 1-800-333-3474, call the tech support of dish network, ask for a service call and inform them that what you did, sometimes they will ask some information, just answer the question, that is only to verify the steps that you did, If 129 sat orbital location is needed on your programming bcoz you have an hd program or your local package broadcast on 129 sat orbital location, they will setup a service call but if the sat 129 is not needed on your programming they will inform you that you dont have to worry about it. granting its needed, they will setup a service call. if you have the extended warranty plan, the service call is $29 but if you dont have, the fee is $49, the extended warranty plan is $5.99 every month. if you have any query pls feel free to get in touch..
Sep 06, 2009 | Televison & Video
Does not receive 110 side
Hi a_mizrahi! I will be more than glad to assist you in thhis concern. If your model 510 dvr receiver dont get the sat 110. Lets check 1st the cable connection on the back of the receiver, make sure that the cable connected on sat in is connected hand tight and check as well if the cable is going to the wall with a connector as well. Then press the menu button on the upper left of the remote, it will pop up the main menu, once you got it, press number 6-system setup, 1 installation, 3 system info, It will show the system info one. check on the field letter g, you will see sat number, ex only 119, bcoz you cant get 110, check if sat 119 is green on the buttom box, if its green then select cancel on the screen, then select 1 pointdish, select on check switch then once you are on the install summary, select test on the buttom portionof the screen. It will run a test it could be 1 of 2 or depends on the situation of your sat dish.. wait till it finish. once its finish, it will show the install summary, check if you have, input1-119-all- device name, input2-110-all-device name, or it could show this way, input1-119-odd-even, input2-110-odd-even, if you got 110 on the input after the test it means that we are almost there to fix the problem.. select cancel on the screen, cancel all the way out of the menu until it will pop up attention 015, it should show a progress up to 5 of 5 then it will download the programming guide, wait until it finish the download and it will pop up a picture right away on the tv. let check if the 110 is ok, most of the channels broadcast under 110 is your local channels and some upper channels from the sat.. press menu and then main menu willshow, press 6, 1, 3, back to system info one, check on the field g if sat 119-green, 110-green, if there is no 110 showed on the field g, cancel alll the way out of the menu, then press the power button on the front panel of the receiver for 10secs to reset the system, it should show on the front panel of the box that the power light will turn off and turn back on by itself, then it will acquire the sat signal again, it will go to the process of finishing the progress and download the program guide again, just incase the front panel reset didnt work, do the hard reset by unplugging the power of the receiver to the wall outlet for 1minute. then plug it back in, it will go to the progress again and download the programming guide.. check again the sat on the system info one, by pressing the menu button on the remote, press 6,1,3, check sat 110 is there and 119, it should be green on the button. granting still no 110 sat, select cancel, then select on the screen updates - option 4 I think, once your there, check if without my permission is selected or check, then save , cancel all the way out of the menu, once you got a picture, press the power button on the remote to turn off the receiver, leave the tv on, wait for a few secs and it will pop up attention 061, downloading vital program information, this msg will appear if your software version is outdated.. wait until it finish and once its finish the tv screen will turn black or snowy screen and no lights on the front panel of the box. push the power button on the front panel of the receiver for 10secs to reset the box and wait till it acquire the sat signal and download the programming guide, this should fix the problem, if there is no changes, please call dish network tech support @ 1-800-333-DISH, to check your sat system, there is a possibility that there is a problem on the alignment of the dish, switch or lnbf..
Sep 02, 2009 | DISH Network DVR 510 DTV Receiver /...
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
Stereo
try the green wire it hooks to the e brake or gound it out so try that
Sep 28, 2008 | Blaupunkt Chicago IVDM-7002 Car DVD Player
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
178 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
