Question about Nokia N73 Cellular Phone
MY N73 WHEN I WAS DOWNLOADING SOFTWARE UPDATE FOR MY N73 THE CONNECTOR WAS REMOVED THEN MY N73 NEVER OPEN AGAIN.. PLS DO HELP ME
    Sergeant:
  • 154 Answers
Sir, this may be due to virus... please give it local service station.. hope i have helped.. thank you sir
Posted on May 04, 2008
Dear sir i want update my N73 softwear. Bt they ask invalid URL adress. So pls tel me wht can i do.
Do not bother just follow the instruction below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link N73 files and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 21, 2011 | Nokia N73 Cellular Phone
Hi, i have problem with my n73 cell and it is very slow in opening the features and sometimes it will appear " memory full delete some data" even if the memory s still spacious. i want to...
Download and install Nokia PC Suite and Nokia Software Updater available from Nokia.com, once installed use PC Suite to backup everything you need on your phone...
Make sure a working sim is inserted into the phone and General profile is selected, plug in the charger and turn the phone on, once fully started plug in the USB cable and run Nokia Software Updater, it will pick up the phones current version and download any updates...
May 09, 2009 | Nokia N73 Cellular Phone
Phone restatrs
Make sure that you insert the SIM only after switching off the phone.If the problem again exists,it may be some software problems.Please reinstall your phone's software or update your phone's firmware.
Apr 08, 2009 | Nokia N73 Cellular Phone
N73 phone lock
update your phone without restoring back up.
http://www.nokia.co.in/get-support-and-software/download-software/device-software-update/download
Mar 25, 2009 | Nokia N73 Cellular Phone
Automaticaly closed my nokia n73 memory card application & sheak
kindly update your nokia phone through nokia software updater ..
Mar 22, 2009 | Nokia N73 Cellular Phone
N 73 Stuck.
If you could not complete your firmware installation,Please re install your phone with the same firmware using Nokia Software updater.
Feb 13, 2009 | Nokia N73 Cellular Phone
N73 Software update 4.0839.42.2.1 failed
remove the cable and before update make a backup then download the nokia software updater from here
http://europe.nokia.com/get-support-and-software/download-software/device-software-update# then wait about 15 minutes thats what the softare tells after that your phone is updated if
Dec 21, 2008 | Nokia N73 Cellular Phone
How to flash nokia N73
you can flash your N73 by using the normal data cable also but your cell must be in working condition for that ...
if your cell is in working condition then you do that by following these below given steps :
1. make a back up of all your data in cell and remove memory card ..
2. download the "nokia software updater " from the nokia website. below is the website given for you:
http://www.nokia.co.in/A4767968
3.install that and keep connected to internet it will automatically download and flashes and installs the new firmware for your cell .
remember dont disconnect or switch off the pc or remove battery while the process is going this may severely damage your cell and it may become unrepairable ....
if your phone is not working presently means then you can buy a DKU series cable which allows you to flash the phone,reset any codes,etc ...
if you dont like to buy then you can just visit some service center and get the cell flashed ... as you are also from india it may cost you some just 200 or 300 rs that s it ...
thank you
regards
-Dileep
rate my solution
Nov 13, 2008 | Nokia N73 Cellular Phone
Delete Data
It's a software fault, doesn't matter how much 'stiff; you delete.
go to: http://www.nokia.co.uk/A4222213#
and you can upgrade your phone software
(you will need to download the updater and back up your data first)
Hope this helps! (If it does pls rate me) :-)
Sep 28, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
