Whirlpool combo washer and dryer model YL TE6234DQ2
  • 36 Answers
What is your problem???
Posted on Aug 22, 2010
Why does the whirlpool washer dryer WET3300XQ1 -leave a detergent trail from the top of washer to floow. Is the deterget leaking from washer?
Make sure hose clamps are tight, both inside and out of the washer.
Check hoses and replace.
Try looking for replacement parts. Do visit http://www.partsimple.com/washer.html OEM parts at lesser price..
Washer Parts Replacement Parts Repair Parts Partsimple com
Oct 17, 2015 | Whirlpool WGT3300XQ Combination Washer/Gas...
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
Any particular problems with installing whirlpool stacker washer/dryer in RV
the main problem is how stable the foundation is for the laundry center when it goes into its spin cycle.
Sep 11, 2012 | Whirlpool LTE5243D Top Load Stacked...
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Its about my washer/dryer combo whirlpool model lte6234dqs: -the dryer don't produce hot air and therefore don't dry. -Anybody please?
check your breaker to the appliance you must have 220 volts before it will heat if you only have 110 volts it will run but not heat otherwise it could be a thermostat or heating element which is hard to say with out me being there to check it out with a meter
Nov 19, 2010 | Whirlpool LTE5243D Top Load Stacked...
I want to know the production date of Kenmore 3394715, stackable washer/dryer combo.
The production date is determined by the SERIAL NUMBER on your appliance. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
Kenmore washers are manufactured by Whirlpool. If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
Whirlpool Combo Washer Dryer LTG6234AW2 - Dryer wont heat
Go to: RepairClinic.com
There you can troubleshoot
you appliance.
You'll need make & model #.
Jul 19, 2008 | Whirlpool LGR3624JQ Gas Dryer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
