Question about Andis Vacuums
My new BGRV blades are getting very hot with only one haircut
How do you replace the mico-sweep blade that is broke
Most of the time, you cannot get a new one of those blades unless you replace the entire base plate. Depends on the model that you have. I would suggest checking with a local vacuum repair shop to see if they can help you. If you go to Oreck's website Oreck Store Locator you can see if you have one near you.
Mar 25, 2014 | Oreck Micro-Sweep Blade 7500901
Red light always on, tried clening the filter but it did not work. I also tried to switch it on without filter and the light is still on. It noisy, get hot and stop working. What should I do?
There are particles still inside the intake chamber surrounding the blades attached to the motor. Over heating can burn up the motor and thus take it for service to an authorized station.
Feb 23, 2014 | Electrolux Zt3520uk T8 Bagless Cylinder...
Brushes wont spin on the vax duel v 124 model and i dont know how to get to the belt to see if it has broken. There is no reset button on here that I can find !!
V124 /124a. Brushes not spinning. A clicking noise can sometimes be heard with this fault. It is likely that the brush drive unit has developed a fault. For the adventurous it is quite straightforward to repair. Ensure the machine is unplugged from the power supply and remove the tanks. Place the machine down on the floor and remove the brush bar. This clicks into place and is easy to lift out. Remove the screws on the base of the machine that hold the red cover in place. These are posidriv self tappers. Remove the clear plastic V assembly from the machine. This is clicked into place to make removal and replacement easy. Locate the turbine assembly and underneath the machine remove the screws that hold this in place. Disconnect the two small rubber hoses on the turbine assembly and gently pry out the turbine. The turbine can be opened up by removing the self tapping screws holding it together. Do this on a well lit bench or tabletop
Gently open up the turbine housing by lifting the black clips slightly. Keep the turbine level while you are doing this. Inside is the black plastic turbine blade. Remove the two gears and the small bearing and place to one side. Inspect the turbine blade for cracks or damage. If cracked the turbine blade can be repaired using a hot soldering iron to 'weld' the plastic. Ensure the repair is smoothed off by using a flat file. A tiny amount of light oil can be applied inside the turbine casing. Then reassemble the turbine blade, gears and bearing and clip the housing together. Replace screws in turbine housing. Refit turbine into the machine Replace machine screws, red cover. clear V assembly clicks back on. Test the machine to make sure that the brushes rotate. If the turbine is beyond repair a new one can be obtained as a spare part
Sep 21, 2011 | VAX Appliances Vacuums
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
Hi. I have an older fein multimaster msxe 636 II. The blades have round bolt holes. The new models have the star type holes. Can I use the star type blades since they are more available?
With respect to the above "answer", this tool has NO locking lever! It uses only a set screw to hold blades in place. It so happens that newer "star" mounting blades will fit into this tool easily, One must center the blade so the fingers of the star are outside of the raised circular surround of the hole. A washer (use a larger tapered one) and the set screw will then press the blade against the back surface of the bit holder. Tighten up this assembly, turn it on a cut away!
Dec 30, 2009 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Hoover windtunnel v2 hair keeps getting caught up in the brush pieces causing vaccumme to overheat and plastic parts to melt
This is a common problem in homes with long hair or pets. A vacuum has the nastiest job in the house. The hair will travel to ends of the brush continually and cause problems on any vac however better quality vacs have thread stops around their bearings or at the end of WOODEN brush roll. You can clean some of the brush with scissors or a utility knife from the outside of the nozzle housing but you must inspect the head continually or you will end up with a ruined brush roll. THAT OR A HAIRCUT FOR THE OFFENDERS.
This is only part of the fix, thew brush will need to be removed thoroughly cleaned from time to time. A wire brush also helps to remove it when you cut through it.
Sep 18, 2009 | Hoover WindTunnel V2 U8148-900 Upright...
Vacuums Logo
Top Andis Vacuums Experts
JoeVacs
Are you an Andis Vacuum Expert? Answer questions, earn points and help others
