Question about Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32' 720p flat panel never had set up wizard when first turned on...cant make it connect to the satellite cable
  • 2,335 Answers
Try to reset the LCD to factory defaults by pressing menu > set up and scroll down to restore all. Have the satellite cable on before you try to run the auto channel scan.
Let me know if you need further assistance.
Posted on Aug 22, 2010
My dynex 19" lcd tv doesn't work when i turn it on and try to set it up all i get is a distorted screen that you cant read i was told that it has to be reprogrammed is there software for a computer to fix...
When you turn it on press the set up/menu button. Make sure your cable is unplugged first. When in set up, go to channel setup and scan channels. Once the scan has started connect your cable back to the tv. Allow some time for the scan to complete. ***I learned this when I emailed a dynex technician. If it does not work after the above, email dynex http://www.dynexproducts.com/contact-us.html
Oct 08, 2014 | Dynex Televison & Video
Hi, I have a DYNEX 32in. 720p Flat-Screen TV. I am on Antenna & I can't get any channels below 16.1. I did Auto-scan. Anyone have any ideas? Thanks, AngelRock.
Do you have any other devices in your setup (cable box/modem, satellite, receiver, gaming consoles, etc)? What type of connection are you using (HDMI, composite/component)? Are you trying to obtain additional channels through a cable scan, or through basic antenna?
Mar 10, 2014 | Dynex Televison & Video
Dynex 32" tv cant get regular channels,
How is your TV setup--do you have a cable box, satellite, or basic cable? I would recommend going into the settings and running a channel search.
Press Menu. The on-screen display menu options with Setup highlighted.
Press RIGHT arrow to enter the sub-menu, then press DOWN or UP to highlight AUTO CH SEARCH.
Press ENTER or RIGHT arrow to start the search.
Oct 10, 2013 | Dynex DX-LCD19-09 19 in. LCD TV
Dynex tv has no picture
Select the correct picture mode and adjust the brightness/contrast. See "Adjusting the picture" on page 13.
Make sure that the antenna or cable TV is connected correctly. For more information, see "Connecting an antenna, cable TV, or satellite TV box" on page 7.
A copy of the manual can be found here: http://www.dynexproducts.com/products/televisions/DX-L42-10A.html
Sep 19, 2013 | Dynex Televison & Video
Connected the cables to the TV and cable box, but when trying to set up the TV for the first time, I selected cable/satellite box and it keeps wanting me to run a channel scan, when I go into the menu to...
okay lets do a cable check... cable from wall /outside connected to cable box in, from the cable box out to (please note any DVD recorder or VCR should be connected here if you have and then on to TV) TV in ..... TV on , turn to channel 3 (this should be the only ch locked on the TV no scan is needed) you are using coaxial cables... if this was/is a hi def connection (your set should be on component)
Dec 19, 2010 | Dynex DX-LCD37 TV
I just bought a new dynex tv and the setup wizard wont let me select cable/satellite box and when i go to the input menu it doesnt help at all
If your using a cbl box or satellite receiver then you don't need the setup wizard. Just put your INPUT or SOURCE on the appropriate setting. Always use a/v or component input for connections.Your done!
Nov 26, 2010 | Televison & Video
Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
When I tried to hook up my dynex tv to my satellite box it kept saying no signal. Do you know what I am doing wrong?
Hello
Check the input setting in the menu setup.
You should have a different inputs such as.
1 cable
2 hdmi
3 sat
Choose sat or satellite.
Apr 06, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Initial set up w/directv
First, I hope you got an extended warranty with that. Otherwise it's a disposable T.V. after your warranty is up.NO PARTS are available. Hope it lasts more than a year..if your lucky. You need to change the channels on the direct tv box. Don't scan the t.v. You need the t.v. on channel 3 or video input that the box is connected to. Do you have hdmi cables? How did you hook the box to the T.V.? Did you read your book that came with the T.V. about hooking it up with a cable box??? Same thing as Direct T.V. box. That should show exactly how to connect. More info will help dtermind your problem.
Dec 05, 2008 | Dynex DX-LCD37 TV
Dynex 32 in. LCD Flat-Panel HDTV Logo
681 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
