Question about Acer Computers & Internet
My fan stops spinning and in turn the comp overheats and goes off
  • 90 Answers
Update the bios and if that does not work replace fan
vote me a 10 when this works for you
Posted on Aug 22, 2010
Engine overheating quickly
there are 2 or 3 fans up front on all A/C equipped cars.
the fan closed to engine (rad rear) turns on parked and idling
all engines will overheat parked, if the fan goes dead.
so are you saying this fan is dead.?
if it dont overheat moving fast then the cooling system is usually good
and then you stop at a traffic light this fan must turn on.
on cars with 3 fans , some stage up, 2 on if too hot. or all 3 on.
the FSM covers this logic clearly.
in the USA car.
the element has 2 fans (some engine options my differ)
the right fan is for A/C
and left fan is for engine cooling, (im looking at alldata.com to see that)
the fan turns on via a relay that he PCM controls
the PCM see the ECT sensor in the engine go to over say 225F and
it closes the relay, and the fan spins at full speed.
fuse 4 runs this relay, in the fuse box
the relay and fuse are named
radiator fan.
Mar 01, 2014 | 2004 Honda Element
I have Compaq v6608AU laptop. When I start the comp it gets booted and windows runs normally. After booting my comp suddenly shutsdown. what is the problem?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
May 01, 2011 | Computers & Internet
My 97 Acura 3.2 TL starts to overheat and I also notice that the air gets cold when the heater is on. But when I begin to drive after stopping, the temp. goes back to normal and the air gets back hot...
Possible thermostat but more likely fan belt is slipping when idling causing waterpump to slow or even stop spinning. Tighten or replace fan belt that runs over waterpump pulley
Jan 03, 2011 | 1997 Acura TL Series
I have fan noise on my new ecs elitegroup GeForce GTX 460, a simple tuch on the fan and noise immidiatly goes away? HELP !!!
Hi samohtpfeffe, i've been having the exact same problem. if fan making noise because you video card is over heating, or you fan is about to die, if the fan stops spinning and this will cause video card to overheat and damage and system lock up or crash, i recommend you replace video card fan as soon as possible, to solve this broblem.
Good Luck!
Dec 01, 2010 | EliteGroup Computers & Internet
I have 2003 grand cherokee with 140000 miles that overheats at idle. as soon as i start moving again, the temp goes back to normal.
You have two fan's on your truck, 1 is a fan clutch runs with the drive belt, 2 elec fan motor, with test light and engine running at normal temp, just a little bit above 1/2 way on your temp gauge check voltage at elec. cooling fan harness if you have voltage at one of the two wire's and fan don't turn on, bad cooling fan motor, on the fan clutch after you check voltage at elec. fan motor turn engine off, with your hand spin drive belt fan if it spin's freely bad fan clutch, replace it.Also check cooling level.Hope this was very helpful
Jan 21, 2010 | 2006 Jeep Commander
Blank screen. Won't turn on.
You could have an overheating problem. The CPU shutsdown when it overheats and won't boot up again until it has cooled down. Check the CPU fan and heatsink assembly. The fan may have stopped spinning or spins slowly and the heatsink is clogged with dust.
Remove the dust and replace the fan if it is faulty.
Sep 11, 2009 | Acer Aspire 5735 Notebook
Raidmax Sirius mid-tower case fan alarm
Here are some solutions:
1. Try to use some silicon oil in fan apertures to decrease rub
2. Try to manually (look for a mainboard's service software settings) decrease rotation speed if available
3. Less recomended: disconnect fan cable from mainboard and don't stress your computer (try not to overheat, - work with software that uses less resources) and buy a new one when available
Jan 28, 2009 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Computer wont boot
yep you said it loose connection, wiggle the power cord and and thing attached.
Jan 08, 2008 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
