Question about Sony DVP-CX995V Multi-disc DVD Player
Hdmi output My Sony DVP-cx995v has hdmi output problem,display screen became green instad of blue.I checked my hdmi cable-is OK. Any solution? Thanks
    Problem Solver:
  • 3 Answers
There is a firmware update available from sony that appears to address this problem. Go to sony and do a search for the model number dvp-cx995v. I have not tried it myslft but the write seems to address your problem.
Posted on Dec 27, 2008
When I connect my Sony DVP-CX995V via HDMI it the TV says there's no signal.
there is interface problem between hdmi port actually signal are not reached in system ic these signaled are dropped between hdmi port & hdmi switching ic so please go to your nearest Sony service center & repair main board because this problem is in main board
Feb 02, 2016 | Sony Televison & Video
Need Operators Manual for Sony Disc Explorer DVP-CX995V
Sony has documentation for the DVP-CX995V on their support site: http://esupport.sony.com/US/perl/model-home.pl?mdl=DVPCX995V&LOC=3#/manualsTab . The direct link to the manual is http://www.docs.sony.com/release/DVPCX995V.pdf .
I hope this helps.
Dec 05, 2011 | Televison & Video
Can not get dvp-cx995v into hdmi output
Sony has a new firmware release to resolve this issue.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=2824&mdl=DVPCX995V You can download it from this site along with the instructions
Dec 03, 2010 | Sony DVP-CX995V Multi-disc DVD Player
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
Sony DVP-CX995V "cannot play"
you can clean the motor by the back side
Oct 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Colours turns blue and green from HD channels
The most likely cause of your problem is the cable box HDMI output. If you have some extra cables, try connecting the TV to the cable box using the component connections. I'll bet your problem will go away. Don't let the cable company lie to you; I work on Sony TV's everyday and see plenty of cable box HDMI issues. Some of my customers have exchanged their boxes 4 or 5 times and still have HDMI issues. Your best bet is to use the component outputs or switch to Dish or Direct TV, as they DON"T have HDMI problems. If this solution works, be sure to rate it. Thanks!
Nov 11, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony DVP-CX995V will not play through the hdmi output
There is supposed to be a firmware fix for that from sony.
Feb 08, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V Multi-disc DVD Player Logo
242 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
