Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
My freezer & refrigerator temps are 47 and 37. Big lighting storm last night caused power outage. How can I tell if it was affected by storm or if something else needs to be repaired?
  • 36 Answers
If you temps go up your gonna have to check the control board on the back of the unit.
Posted on Aug 22, 2010
We have a Samsung RS265TDWP side by side refrigerator. After multiple power outages last night in storms, I discovered this morning the temp on the fridge is 53. I have tried unplugging to reset. Did...
Being a newer fridge I would look at the control board being faulty. They do not Handel porters surges very well and you may have blown a relay or resistor on the board. I would install a surge protector on anything you own with electronics in the future.
Sep 08, 2012 | Samsung SRS20DTD Side by Side Refrigerator
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
We have a Samsung side by side RS2534WW, just had a brief power outage during a storm, now 1 light on the panel blinks, nothing else. Lights are on inside the fridge, but won't deliver ice or do anything....
I simply press and hold the top left and top right buttons (which are for the temp in each section) for about 5 seconds to reset. It's fine until the next power failure...and I don't want that when I'm on vacation.........
Jun 29, 2010 | Samsung RS2534 Side by Side Refrigerator
E had a power outage due to a storm blowing trees down on power lines. When the power returned, about 4 hour later, the refrigerator/freezer (side by side) was making a loud buzzing noise. The ice maker is...
This sounds to me like a busted compressor, nothing more you can do to it. You must call a repairman to test it and replace it, a very delicate procedure that requires specialized equipment.
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Fridge hot, freezer holding coldness but not
check compressor operations. also display board can fail in power outages
Feb 12, 2010 | Refrigerators
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Power outage caused by fridge to quit
OUCH! , the partial digit display is an error code that has a meaning and they are never good , these units I have seen/repaired many times but I do not have the code book to determine it.
Try holding down the power freeze and power cool at the same time until you get something. If the unit is ok it will reset and hopefully be fine , if you still get a code these units have longer warranty's and could be repaired with no charge.
Phil
Apr 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
538 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
