Question about Dryers
Making a screetching/ rubbing noise while on. still working but very noisy.
    Genius:
  • 1,028 Answers
If whirlpool/kenmore remove front panel after lifting top belt idler may be "improved glide type" instead of roller type replace with roller type if roller type ck rear support rollers for wear and rough spindle do not oil wipe spindle clean with wd40 and reinstall rollers being they spin freely
Posted on May 04, 2008
Inner tub base rubbing on outer tub
Sounds like you need to replace the bearings supporting the shaft. Not an easy job without the proper tools and if you haven't done it before.
Nov 07, 2015 | Fisher and Paykel Washing Machines
DRYER MODEL DE7400P FRIGIDAIRE IS MAKE NOISE LIKE RUBBING METAL HOW DO I FIX?
Hi martyski39...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your dryer drum is mounted in the rear with a bearing, most likely the bearing is faulty and making the grinding noise, or maybe two conditions exist.
1...Bad drum bearing noisy
2...Bad drum bearing noisy, and with play in the bearing allowing the drum to rub the felt seal away at the door making metal to metal contact.Check your door for obvious rub signs...
I will include a parts house webpage link where you can look at you "exploded" view of your dryer and order parts also.
Please take time to rate me
http://www.partselect.com/MultiModels.aspx?ModelNum=de7400p&searchTerm=&RefineSearch=0
Aug 30, 2011 | Frigidaire Dryers
HOW DO I SOLVE NOISY BRAKE PADS, ON 2008 VW BEATLE 2008. There is very little ware on brake pads.disk pads all round. Also is there any thing special, one needs to be aware of when pushing back pistons in...
No you sound like you know what your doing, there is nothing to be aware of when compressing the piston back in except make sure there is enough room in your reservoir for the extra fluid that will come back up (you may need to empty some out).
The problem with the noisy pads may be a little more tricky,
is it a squeeling noise you hear when brake?
is it a grinding noise (like metal on metal) when you brake?
or is it a constant noise?
if it is a squeeling noise the most likely senario is dust on the pads and disc's. this is normally a problem with cheap brake pads and may be solved by buying a more expensive brand.
if it is a grinding noise it may mean there is something else rubbing on the disc. once the wheel is off check for any rubbing marks from any part of the wheel or guards that are on the disc.
Aug 02, 2011 | 2008 Volkswagen New Beetle
Great nutone bath fan/light. just completed installation and fan makes soft noisy rattle when running. trick for silenting the noise would be great. thanks
if the blades are metal they may have been bent during installation. try to straighten them. make sure blades are not rubbing anything.
Oct 26, 2010 | Broan-NuTone Home
Rubbing noise rear end but not all the time
Hi.Most scooters use a steel key in each rear hub to drive the wheels. These often get noisy. As the wheel turns the weight is put on the key and then comes of as the wheel keeps turning making a noise each revolution of the wheel. To repair remove the rear wheels and wipe a thin smear of grease onto the axle and key. This will reduce the noise. Hint, loosen the bolts holding the wheel on before raising the rear end to remove the wheels. If you place a support or block of timber under the machine, be careful of the motor brush holders.
Other noises could be gearbox gears worn.
Good luck. Neil.
May 20, 2010 | Invacare Supply Group Invacare Lynx Large...
If i turn on the a.c. the car will start to make a screetching noise when i accelerate and it is very loud
Does the a/c work (get cool)? Sounds like a belt,but you have to find out why. Even an old belt shouldn't make a noise. Check out the belt tensioner
Mar 10, 2010 | 2002 GMC Yukon XL
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
My noisy hoover tumble dryer...help please!
possibly bearings gone on drum shaft
Mar 20, 2008 | Dryers
Ear piercing whistle
Its an inherent problem with any Dynammite model = the fact that the motor is at the front means that it is extremely noisy.
Sep 30, 2007 | Dirt Devil M084600 Dynamite Bagless...
Dryers Logo
145 people viewed this question
Top Dryers Experts
