Question about Maytag Dishwashers
The top rack has broken so that it falls off track
  • 36 Answers
What part on the rack is broken?
Posted on Aug 22, 2010
  • bobnawb Aug 22, 2010
    At least one of the wheels that runs along the track has broken
Top rack on bosch dishwasher will not close properly and door won't close because of this. How do you mount the top rack properly?
You need to make shore the wheels are on the track properly. Check how the rack bellow sits.
Also check at the back make shore nothing has been broken or blocking the wheels from going in all the way.
Regards Craig
Feb 09, 2018 | Bosch Dishwashers
We can't get our flat oven racks in our wall oven - our electrician in to look and he wondered if they were the wrong ones.
We really need a tiny bit of clarification.... Do the oven racks go in at all? Most oven racks have a "bend" in the rear of the rack that requires you to lift up the front as you insert it into the tracks. There is a "bump" at the front of the tracks that this bent part of the rack needs to go under. This is in order to keep the racks from falling out if pulled out too far when removing items. If your racks are either too wide or too narrow to fit at all, then you likely have the wrong racks.
Hope this was helpful, and if it was please thumbs up my response.
Aug 02, 2016 | BlueStar BWO30AGS 30 Single Gas Wall Oven...
Dishwasher rack falls off
Could it be that KitchenAid wants you to replace the entire rack? Check with a local appliance parts supplier if you can because the roller must be a hot replacement item.
Nov 21, 2013 | KitchenAid KUDS30IXSS Builtin Dishwasher
Kenmore elite dishwasher top rack falling
The end of the track facing out has a plastic cap with a half circle molded into it. Slide the half circle sidways to release it from the track. Remove the basket. It will be obvious from that point how the adjusters are attached.
Nov 21, 2013 | Dishwashers
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Two grey plastic pieces came loose. Don't know where they belong inside the dishwasher?They are both the same. They apparently hook onto something on the rack, but I don't have a clue?
If these two grey pieces are about 1 1/2" long and a 1/2" wide. They are used to retain the upper rack onto the tracks to prent the rack from falling out and used as a rack stopper. There are two on the front and two on the back of the top rack. How to insert them may differ dependant on the model. look at the two still attached and you may be able to re-install them.
Aug 29, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
LG DIshwasher
hi Problems with the dish racks usually occur because the racks have been jammed back into the tub housing after they're fully loaded. Careless handling can exert enough force to crack or break the roller wheels or throw the racks off the tracks. The solution is easy: Stop jamming the racks.
The repair is easy, too. Remove the racks by pulling out the tiny metal pins that hold them in the tracks. Or simply lift up on the racks and pull them out of the tracks. Then reinstall the racks on the tracks so that they roll smoothly. If the rollers are cracked or broken, replace them with new ones of the same type. The rollers may be friction-fit to their hubs. Pull them off for replacement. Or, if they are held by tiny spring clips, pull the clips out with pliers, or pry them out with the tip of a screwdriver. If you can't pull the rollers off for replacement, remove and replace the entire rack.
Sep 12, 2008 | LG Dishwashers
Top spinner arm of dishwasher keeps falling off
did you solve this. we have the same problem. the piece that the arm is connected to is slightly broken. I don't want to pay for a service call. let me know what you did.
Sep 07, 2008 | Dishwashers
I have Kitchen Aid Dishwasher Model # KUDMOITJBLO. We began having trouble with the top rack coming out of the brackets on the upper rack track. Kitchen Aid sent me 4 parts # 8268785. The problem is...
I removed the tracks from inside the dishwasher.  Then I was able to carefully remove the endcaps (something I had not been able to do previously) carefully.  The existing broken wheels slid out and I slid two new brackets into each track.   If I attached the tracks to the rack first, I would not be able to clip them into place, so I first replaced the endcaps and then returned the tracks to their positions inside the dishwasher. Reattaching the upper rack is not difficult, but takes two people while I connected the left side, my assistant supported the rack on the right side.  I then connected the right side of the rack.  I slide the rack back and forth to macke sure that is worked smoothly.  We then loaded the dishwasher and washed our dishes as we had in the past.
May 27, 2008 | Dishwashers
Dishwashers Logo
148 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
