Question about Hoshizaki KM-1600S Stackable Crescent Cuber Ice Maker
Ice machine electric wiring blue printes - Hoshizaki KM-1600S Stackable Crescent Cuber Ice Maker
  • Hoshizaki Master
  • 1,151 Answers
Go to http://www.hoshizakiamerica.com/. Click on "Support". fill in the model number of your machine and then click "get manual" and it has the wiring diagrams in it.
Posted on Aug 14, 2014
John deere wiring diagrams
Go to
http://www.deere.com/wps/dcom/en_US/regional_home.page
where you can buy a manual , find out your local dealer .
if you do not want to buy a manual , go to your local dealers parts dept . ask the parts counter man to get you the electric wiring harness blue print for your machine . also online you can go to
www.partstree.com or
http://www.m-and-d.com/ and look there .
hope this helps !!!!!!!!! good luck !!!!!!!!!!!!!!!!
Aug 18, 2014 | John Deere L100 Series
Tip
How to clean the corona wire on Intellafax 2800,2810, 3800 machines
Does your brother printer or fax machine have bad printing such as very light print or spotty print. If you have these problems chances are you have a dirty corona wire. The corona wire is used by the printer to put a charge on the paper so the toner is attracted to it in the pattern that the laser draws out. Below are the directions to clean the wire.
1. Open the front cover and pull out the drum unit and toner cartridge assembly.
2. Clean the primary corona wire inside the drum unit by gently sliding the blue tab from right to left several times.
3. Return the blue tab and click it into the Home position.
4. Reinstall the drum unit and toner cartridge assembly in the MFC/Printer.
5. Close the front cover.
Be sure to return the sliding blue tab back to the home position next to the arrow or you will have dark streaks on your printouts
on Dec 09, 2009 | Office Equipment & Supplies
Where is the electrical box for hosizaki ice machie 255-bh
Not real clear of your question but most machines have the control box in the compressor compartment. It has a switch that shows: Wash, Off, Ice. Your incoming electrical is on the rear of the machine. Hope this helps ya.
May 21, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Does not cycle properly
if water valve still allows water even after unplugged electric wires to it then water cylinoid valve is bad.. if water stopes when unplugged then relay in circuit board is sticking or board defective..
Mar 26, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman cse60a 1a
the only time you will get voltage is when the machine is calling for water. turn power off What are the ohm's at blue and purple with one wire disconnected
Oct 08, 2013 | Kitchen Appliances - Others
No power. checked fuse box. Tried reset. no luck.
If you are sure you have power to the wiring of the machine, check the bin control. If it's frozen in the open position (electrically) or the capillary tube that connects it to the sensing bulb that sets inside the storage bin is cracked, it will keep the machine off.
Jun 18, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I bought a used QY_DUAL4C ice machine with remote condenser, but the condenser is 3 phase, and the building is single phase wiring. What can I do?
you'll either need to have the electric company run a three-phase line, or install an electric converter (aka inverter) to make single phase act like 3
Feb 25, 2011 | Manitowoc MAN-CVD2075 Condenser Unit...
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour happened to call in and popped the right wire in the right place and presto we were in business. Not sure what he did but it worked. thankyou. wal
Nov 15, 2008 | Dishwashers
Washing machine
green and yellow is earth so wire the earth wire to this. brown is live in and blue is neutral in. brown/white is live out and blue/white is neutral out. usually a suppressor capacitor has a diagram printed on it
Oct 15, 2008 | Washing Machines
Hoshizaki KM-1600S Stackable Crescent Cuber Ice Maker Logo
110 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
